weber snorkel #680789 12/29/05 03:47 PM
juggernaut Offline OP
Anyone create a snorkel or custom air cleaner for their Weber. Looking for some ideas on how to make it more watertight. That cheesy square air cleaner isnt going to cut it.
Got some free time while I wait to get it owed back home.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15
I caught this "JEEP thing" of your and now it hurts when I pee.
Re: weber snorkel [Re: juggernaut] #680790 12/29/05 04:24 PM
DanWheeler Offline
like i said in your other post, your kinda on your own for creating a snorkel setup for the Weber.
here's my air intake system: (sans the snorkel at this time)
Larger Photo
I got the plenum that sits on the carb from a friend. Refer to your other post where I gave you a link to that part. You can also get a K&N plenum for your Weber but they are spendy. From there you can just go to the junkyard and get some hose parts. I have about 3-4 different vehicles worth of parts going from the carb to the fender. The airbox is from a V6 Montero.
The rest is easy - Safari Snorkel or custom.
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: weber snorkel [Re: juggernaut] #680791 12/29/05 05:16 PM
W
wyleone Offline
With a little imagination and a K&N Filter adapter , You can modify a Dakota airbox to fit. I got the adapter for $30 and the dakota airbox for $25.
Re: weber snorkel [Re: wyleone] #680792 12/29/05 05:17 PM
DanWheeler Offline
where in the world did you get the K&N adapter for $30?
1986 Montero 2.6l
Re: weber snorkel [Re: DanWheeler] #680793 12/29/05 05:33 PM
W
wyleone Offline
That included shipping. I got it from Quadratec, but I would recommend getting it from Pep Boys or any other retailer that sells K&N products. Quadratec gave me a bunch of crap about it not being a Jeep, then a few wrong orders and finally on the third attempt got the adapter. It's the snorkel part of the K&N setup that costs so much, something like $120. But the plate in the link pic is around $30. Then just get the top half from a 98-03 Dakota V6 or V8.
The big problem is the Weber has a pass though for choke linkage from behind the choke coil. It allows dirt and water up through it. The only way around that is to disconnect and remove all the choke components and seal it with RTV. If you don't believe me, just look.
Re: weber snorkel [Re: wyleone] #680794 12/30/05 12:56 AM
Jamez Offline
Is there a way or have you already come up with one to connect the airbox to the fender like the factory intake?
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: weber snorkel [Re: Jamez] #680795 12/30/05 01:13 AM
W
wyleone Offline
I fashioned two brackets out of aluminum flat bar to mount from the factory Dakota mounting points and mounting tabs already located under it for the vacc cannister lines.
The bottom of the Dakota airbox countours the right inner fender quite well.
Re: weber snorkel [Re: wyleone] #680796 01/31/06 03:05 PM
What year was that dakota intake off of?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6223 MB (Peak: 0.7061 MB) Data Comp: Off Server Time: 2026-06-06 20:19:55 UTC
