Re: 22 R engine id #s [Re: kyle-22r] #682014 01/03/06 05:50 PM
P
pugski1043 Offline
I did the EFI swap using an 85 carbed block from a 2wd and took everything off of my 94 EFI engine. From what I understand post 85 engines are all interchangeable. You can also look for the flying saucer laser block identifier that is on the exhaust manifold side. I was also told to use the oil pan from the 4wd and also used the 4wd dipstick.
1994 Toyota Pickup 22RE, EB 268 cam , 2.25 LCE exhaust.
1988 Toyota 4Runner, mostly stock but hopefully not for long
Re: 22 R engine id #s [Re: 4WD22R] #682015 01/04/06 03:24 AM
tgzzzz Offline OP
Yeah, it's amazing what some people will tell you....even shops that are SUPPOSED to specialize in Toyotas.....idiots
Feedback: I called the d[st]ealer and the PARTS guy told me all those numbers were the same and implied that I had a couple of rod bearings loose for thinking otherwise.
It's a wonder the world keeps turning ...
87 JX Zuke bone stock almost cherry
86 Heavy Chevy 350 one ton 26' RV
There's always time to do it over.
Re: 22 R engine id #s [Re: tgzzzz] #682016 01/04/06 07:02 AM
4WD22R Offline
WHAT? all the numbers on the block are the same? thats a good one.....what's this world coming too......another reason why I work on my truck and a select number of people that I know personally.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: 22 R engine id #s [Re: tgzzzz] #682017 01/04/06 11:03 AM
kewlynx Offline
And which numbers were those?
I'm gonna tell you something--
Sometimes you need to be standing at the counter to deal with people. If they still give you the same line of BS, go elsewhere.
As a female, a retired GI (they see you coming), and as a Yotahead, sometimes your PRESENCE exceeds the effectivity of a phone call. <img src="/forums/images/graemlins/evil.gif" alt="" />
**ubi apis- ibi salus**
Re: 22 R engine id #s [Re: kewlynx] #682018 01/04/06 03:43 PM
tgzzzz Offline OP
I hear you Margie, but sometimes I'm just too disgusted by ignorance to argue. Besides, that was my close dealer (30 miles away) and I may need him down the line for something.
Anyhow, from all posts I get that if an engine's got a single timing chain it's gonna bolt to my trans and manifolds which is what I'm after. <img src="/forums/images/graemlins/kewl.gif" alt="" />
And I suppose logically if the engine has a higher # than ~196775, it's newer than my 87 although I now realize that there's no reason to think that a newer block has fewer miles on it than the 210K I've got now.
As I've learned more over the past couple of weeks, I find I'm actually looking forward to the overhaul. I will own a STEEL rail TC guide (and new pistons) by next week. My show truck will soon be a go truck again.
Thanks to everyone. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 22 R engine id #s [Re: tgzzzz] #682019 01/04/06 08:40 PM
kyle-22r Offline
and for purposes of a rebuild, a block that's seen hundreds of thousands of highway miles is a better candidate than something that's been beaten on out in the woods. the cylinder walls won't generally need as much of an overbore <img src="/forums/images/graemlins/cheers.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6188 MB (Peak: 0.6891 MB) Data Comp: Off Server Time: 2026-11-18 03:28:10 UTC
