Re: Gas spews out #682945 01/10/06 10:54 PM
logansportage Offline
Never had this problem. Did you take pictures of where this box is located that you could post so the others that have had this problem can try the same fix?
Re: Gas spews out [Re: logansportage] #682946 01/12/06 11:09 PM
I did not take and pictures. The plastic box that the charcoal filter is in is easy to spot. It is about the size of a shoe box or a large loaf of bread and is just in front of the rear bumper between the frame rails. It is held up by four 10mm bolts, two on each end.
The small plastic box that is on the end of the charcoal filter has a baffle on the end of it and I bent it to one side to get at the felt filter with my neddle nose pliers.
Re: Gas spews out #682947 01/13/06 05:38 PM
I'll have to look at mine again, because I don't remember seeing this when I did my suspention lift or when I did my body lift.
Re: Gas spews out [Re: logansportage] #682948 01/15/06 04:29 AM
Logan,
The Wife's Sportage is a 2002. Not sure if every year would have the same type of canister or in the same place.
Lobo
Re: Gas spews out #682949 01/16/06 11:58 PM
Got ya.
Haven't had time to look under mine yet. Just got 9" of new snow in the valley over the past 3 days, and had to hit the local ski slope for some much needed R&R. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Should have taken today off for a second trip to the slope. <img src="/forums/images/graemlins/angry.gif" alt="" />
PHP: 7.4.33 Page Time: 0.273s Queries: 15 (0.175s) Memory: 0.6053 MB (Peak: 0.6679 MB) Data Comp: Off Server Time: 2026-10-21 17:13:53 UTC
