22RE Being A Little Of A Problem #683204 01/06/06 05:39 AM
Smoke Offline OP
88 Pick-up 4WD 22RE Manual Shift.
New remanufactored long block, got it after engine was installed and had to do the wiring and vacuum hose hooking up. First 22RE that I've played with since mine's a 3.0 and it's being a problem. Hooked everything back up, I think not sure, but it fired right up and idles fairly good but when you open the throttle it starts pulsating up to about 2500 rpm and backdown. Nothing changes reguardless of where you hold it WOT or anywhere else until you release the throttle and then it will idle back down fairly steady. Ran out of time and light tonight so I've really haven't got to check it out to see what might be the problem but thought someone might be able to start me in the right direction. I do believe I hooked all the wiring back but will have to verify the vacuum routing tomorrow!! Somebody have an idea where to start. Never had this problem before, alway a rough idle but now it's just the opposite!! Dang my luck, I hate having to finish what somebody else started!! All ideas or suggestion are appreciated!!
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: 22RE Being A Little Of A Problem [Re: Smoke] #683205 01/09/06 10:15 AM
my buddy had the same problem with his acura after it was rebuilt after hours of work he found out it was just the spark plugs
Re: 22RE Being A Little Of A Problem #683206 01/09/06 08:29 PM
Smoke Offline OP
Problem solved, it was the TPS!! Thanks!!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5876 MB (Peak: 0.6417 MB) Data Comp: Off Server Time: 2026-06-11 08:16:55 UTC
