Page 4 of 5 1 2 3 4 5
Re: 4.3 vortec [Re: Kevin C] #683237 01/29/06 06:29 AM
don Offline
Kevin,
I doubt I've got the acceleration of that turbo!
I needed the displacement for trailer hauling at lower rpm's.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: 4.3 vortec [Re: don] #683238 01/29/06 06:33 AM
LandRaider Offline
You are correct Don.
2 HEI distributors.
1 small one with remote mounted coil
and 1 large one with the coil built into the cap.
I have a large one in my chevelle, and a small one in the raider. both work fine.
As far as simplicity. TBI man. I just HATE carbs is all.
hahah "seems like alot of work for 190 hp"
You're missing the point of the swap man. there are TONS of other advantages to it than JUST doubling the HP
Re: 4.3 vortec [Re: LandRaider] #683239 01/30/06 03:59 AM
RoryTek Offline
Question, when you smog the truck do you smog as a Chevy or a Mitsu?
Rory N6OIL
88'Monty 2.6l 2dr,5spd,Silver,2 bouncy seats,LSD
Most Wanted Synthetics
Re: 4.3 vortec [Re: RoryTek] #683240 01/30/06 04:47 AM
don Offline
The local rules here in Vancouver (Canada) are that the vehicle is tested to the chassis year requirements.
Since the 4.3 produced 1/10 the pollutants of the 2.6, it was an easy pass.
If tested to the engine year, it would have passed too.
An engine/exhaust has to be pretty suspect here to fail.
I took mine through the test (dyno'd, 5 gasses) right after it was running, just to see if I was due for a "surprise" next year, and it did just fine. The tech's updated the records to show the new engine size, and were curious about the swap, but otherwise nothing caused any problems.
Re: 4.3 vortec [Re: RoryTek] #683241 01/30/06 06:13 AM
Kevin C Offline
In CA the engine must be the same model year or newer and meet the same or tighter specifications. So if the Engine is a 98 model year, you have to meet those specs.
Areas with air quaility problems get a dyno test, not so bad areas a standard sniffer test and if you out in the boonies you only get smogged when you buy and sell.
Kevin C
Re: 4.3 vortec [Re: Kevin C] #683242 01/30/06 07:37 AM
RoryTek Offline
Gee wiz talk about being torn on which way to go on a re-power project I'm looking at the diesel route and the 4.3
But diesels donor trucks are hard to come by, but Chevy/GMC are a dime a dozen. Plus parts are a whole lot easier to get. So if I were to poll everyone my bet would go the 4.3 route.
Rory N6OIL
Re: 4.3 vortec [Re: Kevin C] #683243 01/30/06 02:44 PM
conner Offline
The only free ride is supercharging by an exhaust driven system of a belt driven pump. You get your power and at whatever RPM you want it at. Kevin
Kevin: What is an exhaust driven system of a belt driven pump?
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: 4.3 vortec [Re: conner] #683244 01/30/06 07:40 PM
TommyM Offline
It's a new hybrid turbo/supercharger. The supercharger pump is belt driven. The "exhaust" from the belt-driven supercharger then spins the turbine in a more-traditional turbocharger.
What Kevin's talking about "free" is that, with careful sizing of the belt pulley ratios and the "exhaust" wheel on the turbine, the system actually generates more energy than it consumes.
Kinda like cold fusion.
90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter
92 bone stock base model beater
Parting out 4 more
Re: 4.3 vortec [Re: TommyM] #683245 01/30/06 08:14 PM
Kevin C Offline
The only free ride is supercharging by an exhaust driven system or (typo edit) a belt driven pump. You get your power and at whatever RPM you want it at.
I missed by one letter when typing... Basicly some form of supercharging ( forced induction) is a good way to get signifigantly more power out of a given sized engine without having to increase the RPM.
Kevin
Re: 4.3 vortec [Re: Kevin C] #683246 01/30/06 08:57 PM
conner Offline
Kevin
Ok, I should have seen that. The reason i asked is that someone i was talking to at an automotive show claimed that Nissan was experimenting with a combination positive displacement/tubocharger system. As this did not make a whole lot of sense to me,i have been looking for information,to see if it actually exists and how it functions.
TommyM
Cold fusion will never work in a hot engine. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6395 MB (Peak: 0.7488 MB) Data Comp: Off Server Time: 2026-05-29 17:04:29 UTC
