Re: Frame is roting! What should I do? #683505 01/08/06 01:59 AM
Gizzy42 Offline
POR-15 is really good stuff. I've only used their gas tank sealer for motorcycles but the rest of their stuff should be just as good. I still have a nice silver splotch on my hallway wall and my work boots (long story <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> ) You have to grind it off, sand paper doesnt work very well against it.
It wont do you much good if your frame is rusting from the inside (usually from plugged drain holes) but will help against rusting from the outside if you live where they use alot of salt on the roads. Glad they use sand (more like rocks) here along with magnesium chloride. Does nasty things to unprotected aluminum but doesnt make the whole vehicle rot away.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Frame is roting! What should I do? #683506 01/08/06 02:21 PM
Samp, I wirebrushed mine, sprayed some rust convertor down, and the used black engine enamel to cover it back up, as I saw it was resistant to grease and dirt, so why not.
Re: Frame is roting! What should I do? #683507 01/08/06 11:29 PM
TrooperJ Offline
<img src="/forums/images/graemlins/barf.gif" alt="" />
This makes me glad i dont live in the salt belt!!!
-J <img src="/forums/images/graemlins/barf.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: Frame is roting! What should I do? [Re: TrooperJ] #683508 01/09/06 12:00 AM
yeah lucky <img src="/forums/images/graemlins/pfft.gif" alt="" /> I can't wait to get of college and move south. Maine DOT likes to throw sand/salt down even when there isn't any precipitation. Preventitive measure <img src="/forums/images/graemlins/angry.gif" alt="" /> CROCK OF BULL!! I guess I'm gonna have to get underneath the Troop and start brushing away <img src="/forums/images/graemlins/zombie.gif" alt="" /> I guess I'm gonna have to take a break from studying my construction surveying homework and get it done before my problem gets any worse. Good thing it's 15 degrees up here <img src="/forums/images/graemlins/angry.gif" alt="" /> I'll just need a few more brews when I get back lol..Wish me luck...
Re: Frame is roting! What should I do? #683509 01/09/06 12:13 AM
96TrooperSE Offline OP
Yeah its unseasonably warm in wisconsin at 35. So I guess I dont have an excuse not to get under my trooper and start scraping and brushing rust off. Last night I took a hammer an screwdriver and went all around the frame looking for more spots I could poke through. I couldn't poke through in any new spots so thats good. There was quite a bit of surface rust though.
/1996 Trooper SE\
OME 912's w/2.5" spacers, Superwinch hubs, 265/75R16 Yokohama Geolanders (street), 34x10.50x15 Super Swamper LTB's, Indy4x HD Tie Rods, Indy4x Rock Sliders
Re: Frame is roting! What should I do? [Re: 96TrooperSE] #683510 01/09/06 01:38 AM
Sc0rp10n Offline
Living in the salt best adds lots-o-chores you have to do to keep your frame up. I personally will be screw drivering, and wire brushing my entire frame (where I can reach) and sealing it all up.
I've learned my lesson from the Amigo, if I had paid more attention and gave her a little more attention most of my problems could have avoided. Poor thing..haha.
Samp, I'll see you next year <img src="/forums/images/graemlins/kewl.gif" alt="" /> Got my acception letter in the mail yesterday.
Nick <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: Frame is roting! What should I do? [Re: Sc0rp10n] #683511 01/09/06 06:25 AM
I'm going to get some rocksliders and was wondering if I should put them on before or after I use that Por-15 stuff.
The surface will probably have to be clean metal for them to weld and if the Por-15 is hard to get off them I should probly get them welded on before.
/1996 Trooper SE\
Re: Frame is roting! What should I do? [Re: 96TrooperSE] #683512 01/09/06 02:20 PM
RobG Offline
are welding them on? if so, the surface definitely should be clean metal. the heat from the welding will also bubble the surround por-15/paint. I would definitely apply after installation.
-Rob
Re: Frame is roting! What should I do? [Re: RobG] #683513 01/09/06 04:29 PM
BigSwede Offline
Another alternative to POR-15 is Rust Bullet. I put some Rust Bullet on my Tahoe sliders from Stinkyfab, and it is holding up nicely after two years of getting sand/salt blasted in the winter (Tahoe is my DD).
Serenity now!
Re: Frame is roting! What should I do? [Re: RobG] #683514 01/09/06 06:52 PM
-Rob
I am getting them welded on so I'll put them on first before using the Por-15.
/1996 Trooper SE\
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6376 MB (Peak: 0.7455 MB) Data Comp: Off Server Time: 2026-07-14 12:26:40 UTC
