Page 2 of 3 1 2 3
Re: brakes??? [Re: Jake97T] #684347 01/15/06 04:08 PM
L
lawnmowerman Offline
trading in my truck for a Subaru WRX Sti sounds real nice sometimes to me....which would solve my lack of power issues, leaking valve covers, rubbing tires...etc
Do you think those 35's will rub on that Subaru? <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: brakes??? [Re: lawnmowerman] #684348 01/18/06 05:27 PM
ErikB Offline
Toyota Moderator
The Front Range kit is WAY more than just a rear disk kit. That is why its so expensive.
If you just want rear disks, kits like from Allpro and Sky Manufacturing are the cheaper/simpler way to go.
http://sky-manufacturing.com/suspension2.htm
http://allprooffroad.com/index.php?option=content&task=view&id=33
http://home.4x4wire.com/erik
Re: brakes??? [Re: ErikB] #684349 01/18/06 05:43 PM
Squeezer99 Offline
Will both of those those fit the T100? It looks like they are made for the Hilux Pickup and 4runner.
Re: brakes??? [Re: Squeezer99] #684350 01/18/06 06:17 PM
F
Flannelman Offline
It should fit since toyota makes most stuff interchangable. I would like to do this eventually along with the tundra brake upgrade. My question is doesn't the T-100 come up with a bigger master? I thought it would since its a bigger truck but idk so could some please clear this up?
1997 T-100 100k and counting Green
5spd 4x4 Ext Cab isr mod Aisin Manual hubs
Re: brakes??? [Re: Flannelman] #684351 01/18/06 06:47 PM
surlynkid Offline
what do you think you will get from a tundra? T100 has the bigger master.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: brakes??? [Re: Squeezer99] #684352 01/18/06 06:48 PM
surlynkid Offline
yes they will.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: brakes??? [Re: surlynkid] #684353 01/19/06 03:57 AM
speedlever Offline
Would these kits preserve ABS?
--speedy
White '98 T100 SR5 4x4 ExCab Auto - wrecked.
2008 Honda Ridgeline RTS replaced the T100.
Re: brakes??? [Re: speedlever] #684354 01/19/06 02:32 PM
surlynkid Offline
isn't ABS a sensor in the third member?? if so, it should't change anything.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: brakes??? [Re: surlynkid] #684355 01/19/06 10:46 PM
F
Flannelman Offline
I have to dbl check but I believe that the 199mm Tundra calipers are bigger than what comes on our Trucks stock but then again it wouldn't be the first time I've been wrong <img src="/forums/images/graemlins/notooth.gif" alt="" /> Though does anyone know if the master in the T is setup for 4whl disk or does it still need the FJ80 master for the dual anti flow back valves? I know Chilli runs his without.
Re: brakes??? [Re: surlynkid] #684356 01/19/06 11:18 PM
ErikB Offline
Toyota Moderator
Yes those kits fit a T100, and yes I think ABS would still work.
And a bigger master does NOT mean stronger brakes. In fact, if you left everything else the same and only changed to a bigger master, your would LOSE braking power.
Read here for more info on that:
http://home.4x4wire.com/erik/4runner/brakes/#Basics
The master is only a piece of the system, and its size is matched to the other parts of the system (caliper piston size, pedal leverage ratio, rotor diameter, etc.).
Yes, a Tundra uses a smaller diameter master cylinder (and a smaller brake booster too!), but a lot of other stuff is different as well. You couldn't say which vehicle has stronger/better brakes without a whole lot more information.
FWIW, I was considering downsizing the MC in my T100 from 1" to 15/16" for increased braking power to make up for the increased tire size/weight. <img src="/forums/images/graemlins/nana.gif" alt="" />
(never got around to it though)
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6414 MB (Peak: 0.7505 MB) Data Comp: Off Server Time: 2026-10-21 20:41:55 UTC
