Serpentine belt keeps shredding #684753 01/10/06 08:44 PM
get2now Offline OP
Here's the problem;
The belt usually lasts about a hundred miles before it shreds and has to be replaced or comes off entirely.
Background, (second hand information on work performed);
1982 Jamboree, 258 six cylinder carburated engine catches fire. Carburation replaced with MoPar fuel injection.
It appears to be a quality job other than the belt continuously coming off.
In the attached pictures it shows how its getting shredded. The belt is walking backwards on the harmonic balancer to a point where it almost comes off but it never makes it that far because it shreds first.
I thought I had this problem solved when I changed the 6 rib belt for a 5 rib belt. As you can see the 5 rib belt is coming off too.
[Linked Image]This is what it looks like with a new belt on. When the engine is revved up you can see the belt on the water pump walk back towards the engine. You could also see this happen when the 6 rib belt was on.
I guess what I'm mostly thinking is, when this type of swap is done is the harmonic balancer or any of the other pulleys replaced? If so, can one of them have been replaced with the wrong one?
Anybody ever have this problem or am I the only one? <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks for any help.
Gary
Re: Serpentine belt keeps shredding [Re: get2now] #684754 01/10/06 10:47 PM
NCBBA2358 Offline
I can only guess that either you have a bent bracket for something or something isn't tightened down causing misallignment of the belt from one pully to the next. I've never seen one as bad as you are depicting, but shouldn't be too tough to figure out.
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: Serpentine belt keeps shredding [Re: get2now] #684755 01/10/06 10:50 PM
NCBBA2358 Offline
after a closer look, your PS pump looks to be off alignment a bit... the intake from the carb, is it the same as the one for your fuel injection? if not, the alignment of that pully could easily be a HUGE problem....
Re: Serpentine belt keeps shredding [Re: get2now] #684756 01/11/06 12:10 AM
BigJim Offline
What to do is to get a straight edge ( a small ruler or some small iron stock or anything srtaight that will fit in a tight space) and place the straight edge on each of the shivs.. the straight edge should point zackly straight to the next shiv. When you find the one that is OUT adjust it to fit.
From your description I would allow the shiv upstream from the harmonic balancer is the shiv that is out of the loop.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6014 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-06-03 13:21:31 UTC
