How much would it cost to put dual cases in my truck? #684815 01/11/06 02:05 AM
87Toy4x4 Offline OP
after i buy the $350 adapter kit from marlin, can i just get another stock tcase and bolt them up. i know id have to get a new driveshaft, but im not sure how much all of this will cost. i dont want to start spending money on something and then realize it is a lot more expensive than i thought.
Re: How much would it cost to put dual cases in my truck? [Re: 87Toy4x4] #684816 01/11/06 03:02 AM
BeaterToyota Offline
It can add up to about $1000, but nowadays there are more products available and it can be done cheaper.
The basics that you need:
the adapter
shorten rear drive shaft $50-$75
lengthen front drive shaft $75-$100
buy the donor t-case and modify it (or buy a modified case from Marlin, Inchworm, etc.).
get a new crossmember to protect the second case
buy a second rubber t-case mount to bolt to the second case to the crossmember
buy a cool third shifter knob, like a skull with light up eyes.
Jason
'88 Toyota, flatbed junker, Inchworm dual cases, spooled rear.
Re: How much would it cost to put dual cases in my truck? [Re: 87Toy4x4] #684817 01/11/06 01:50 PM
wr250 Offline
cost me around $600
mc08 adaptor ($475 got it from someone who was desperate for money, new still in box)
L52 donor trans/transfer case $50
misc steel $50
oil , misc parts $25
did the work on d/s myself with friends help.
front is square shaft
rear is shortened
85 runner -dual cases, headlight harness, 34" TSL's
86 toy buggy getting sas'ed with a 14 bolt rear - 8.5" 10 bolt front (this will go away when i find a 60)
Re: How much would it cost to put dual cases in my truck? [Re: BeaterToyota] #684818 01/11/06 02:55 PM
fourwd1 Offline
...buy a cool third shifter knob, like a skull with light up eyes.
That's where the big $ goes.
<img src="/forums/images/graemlins/notooth.gif" alt="" />
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: How much would it cost to put dual cases in my truck? [Re: fourwd1] #684819 01/11/06 05:16 PM
bkg Offline
Lessee...
The first time I did it cost over $3K.
Marlin ultimate 23 spline w/ V6 adapter: $2400
Drive shafts: $750
Twin Stick: $200
crossmember: $50
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Prices have dropped quite a bit since then, however.
Brian K. Gallus
Re: How much would it cost to put dual cases in my truck? [Re: 87Toy4x4] #684820 01/11/06 08:41 PM
L
labomba89 Offline
Sorry to chime in, but what about Marlin Crawler's "Crawl Box?" I'm sort of oblivious as to all the transfer case stuff, but it should include a transfer case (or something with the same purpose and different name) AND the adapter AND shifter knob (sorry, no skulls though). I'd figure it would be everything needed except mod's to the floor board, drive lines, and cross member.
Am I reading this right or am I confused?
http://www.marlincrawler.com/htm/transfercase/pickup_dual.htm
Called "Crawl Box Dual Crawler Kit"
Re: How much would it cost to put dual cases in my truck? [Re: labomba89] #684821 01/11/06 11:18 PM
mt_goat Offline
Dual cases are really 1 1/2 cases, that is the 1/2 part. You also need another gear driven case behind that, preferably 23 spline.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: How much would it cost to put dual cases in my truck? [Re: mt_goat] #684822 01/11/06 11:49 PM
87Toy4x4 Offline OP
so i can just get the dual case kit for $659 and only worry about the driveshaft?
Re: How much would it cost to put dual cases in my truck? [Re: 87Toy4x4] #684823 01/11/06 11:54 PM
DirtyHarry Offline
Toyota Moderator
Not exactly. In addition to the driveshaftS (and driveline angles) you would need a new crossmember.
Plus, your truck likely has a G series transmission and forward shift transfer case that will need to be converted to a top shift case in order to work with the dual transfer cases. You can likely swap your forward shifting case for a complete top shifter from Inchworm or Marlin for an additional price.
Re: How much would it cost to put dual cases in my truck? [Re: DirtyHarry] #684824 01/12/06 12:13 AM
87Toy4x4 Offline OP
yeah i know i have to replace the crossmember. i was planning on doing that first w/ one from budbuilt. i do have a g52 transmission though so i guess i would have to convert it. if i had a r151 would i have to convert it to top shift?
PHP: 7.4.33 Page Time: 3.242s Queries: 16 (0.003s) Memory: 0.6440 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-05-28 12:33:53 UTC
