Page 2 of 3 1 2 3
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: hupptoy] #685131 01/13/06 12:08 AM
SHAD Offline OP
Looks like it's a 4.56 diff. I checked the ring gear it has a 41 stamped in it.
I counted the teeth on the pinion it looks like 9.
So 41 teeth on the ring and 9 on the pinion so it's a 4.56 right?
Anyways already installed it the power doesn't feel bad at all it turns my 35's fine actually feels a little pepier without a locker in the back.
Anyways found a cool calculator:
http://www.csgnetwork.com/rnggrpinioncalc.html
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: hupptoy] #685132 01/13/06 01:24 AM
Snowtoy Offline
I was under the impression that 31" tires were only an option with the V6 and that all 22's came with 225's (at least for 89-95 trucks) from the factory.
So a 22RE 5-spd (89-95) pickup would almost always have 4.10's.
Let me know if this is not the case...
hupptoy
Generally this would be correct for a 22re 5-sp(same for stock 3.0's 5-spd's w/o 31's except of having 4 pinions instead of 2). However depending on what options a dealer offered(and what the buyer was willing to pay), 22re's w/the 5-spd's could have come with the 31" tire package and 4.56 gears. It is always a good idea to check the door tag codes and also count the teeth to make sure, unless you are buying from an original owner who still has the dealer sticker.
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: hupptoy] #685133 01/13/06 03:05 AM
Brian894X4 Offline
hupptoy
Well, after looking at my '89 brochure , it does appears that at least for '89 pick-ups, the 31" tire option was only available on V-6 trucks, no 4 cylinder models. Not sure about later models, including 1990 and later 4Runners.
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: Snowtoy] #685134 01/13/06 03:00 PM
hupptoy Offline
I agree that the dealer could have changed the tires/gears (or anyone else could have...), but I doubt that they would have changed the door tag to indicate this.
So the only way to know for sure is to count either the teeth or tire revolutions (if 3rd member is still installed).
Also, on my 4Runner with factory 31" (well, 265/70-16) tires, the door tag still indicates 225 tires, and I have yet to see one that says 31" (or 265...) on it. If I decode the axle codes from the sticker, it does indicate I have 4.10's (but I knew that since I bought it new and still have the window sticker).
So, the only way to know for sure is to count...
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: hupptoy] #685135 01/13/06 07:04 PM
SHAD Offline OP
Nope I was wrong it's definately a 4.11 carrier.
For some reason toyota factory 4.11's were painted pink on the end. Mine definately is so I think I miscounted teeth on the pinion.
Anyone else know about the color codes on the pinion ends?
86 Toyota 4 runner
My cardomain page
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: SHAD] #685136 01/13/06 08:10 PM
V
Voyager Offline
Look here. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: Voyager] #685137 01/13/06 11:38 PM
TNToy Offline
My 89 4Runner with a 22RE had 4.56s stock.
I bought a chunk out of someone's bare axle (dunno the year, but it WAS an IFS rearend) and it was 4.56 too.
That's why I'm running 4.56 gears, not 4.10 like I thought I was going to. <img src="/forums/images/graemlins/lol.gif" alt="" />
Yeah you prolly mis-counted the pinion: 4.56 and 4.10 both have 41 teeth on the ring gear:
41 ring 9 pinion = 4.55555555 ratio
41 ring 10 pinion = 4.1 ratio
So go take a good, long look at the pinion - it's hard to see down in there. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: hupptoy] #685138 01/14/06 09:48 AM
Snowtoy Offline
hupptoy
All the ones that I come across with the factory 31's also still list 225's, the only thing different on the door tag is the gear code being G25? instead of G29? for 4.10's.
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: Snowtoy] #685139 01/14/06 10:28 PM
trythis Offline
So how the heck are oyu supposed to know what tires to put on if you wanna go factory spec? If I have 4.56 would I put 225s or 265?
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: trythis] #685140 01/14/06 11:16 PM
kyle-22r Offline
4.56 trucks came with 31" tires.
'91 4x4 shortbed
22R-E, W56, the dd!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6473 MB (Peak: 0.7540 MB) Data Comp: Off Server Time: 2026-05-30 02:24:24 UTC
