Page 3 of 3 1 2 3
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: trythis] #685141 01/16/06 03:28 AM
Snowtoy Offline
So how the heck are oyu supposed to know what tires to put on if you wanna go factory spec? If I have 4.56 would I put 225s or 265?
Since yours is an auto with the 4.56's and you want to keep it is stock spec's, you don't want to go any taller than the 225's(28") tire. With your auto tranny and 4.56's your stock tire package was the 225's. If you upgraded to oem 4.87's you could then run 31's and be within stock spec's. Or, you could convert your rig to a 5spd and then be able to run 31's with the 4.56's, or 33's with the oem 4.87's, etc.
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: Snowtoy] #685142 01/16/06 05:10 AM
trythis Offline
Never any way to tell, some people say "all 4.56's are 31 stock" some say only stick shift.
No intrest in owning a stick or bigger tires, but eventually I will need new tires, I have 30x9.5 15 and when I replace them I am getting some nice quiet road tires, I jsut wanna know what size I am supposed to have.
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: trythis] #685143 01/16/06 07:24 AM
hupptoy Offline
stock was 225/75-15.
Although you could use 235/75-15 on up to 31x10.50. Just be a little slower the bigger you go.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: hupptoy] #685144 01/17/06 07:23 AM
A
Andy87 Offline
Anyone know why a truck would come with 4.30 gears? I just bought a '92 Xcab V6 5spd 4x4 and the axle code is G284. It's got an R150F trans. The jamb sticker says 225/75s were stock. Were they a specific option you could choose, or was it some other trim/mechanical package that came with 4.30s?
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: trythis] #685145 01/20/06 04:40 AM
Snowtoy Offline
If you are happy with the performance(mileage/power/ride) of the 30's, I would buy new 30's when it comes time for new tires. If you want better mpg and power, you should go with the 28" tires.
Andy87
Yours is the first I have heard of a 3.0 5spd comming stock with anything but 4.10's or 4.56's. I could see the the taller gears for a commercial type rig that was going to be hauling a lot of weight on a constant basis. I wonder if the original owner was planning on a camper conversion or running a commercial bed.
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: Andy87] #685146 01/20/06 06:25 AM
Rusty Davis Offline
Just an FYI, but I haven't seen a door jamb sticker that actually lists 31x10.50's. This may only apply to certain vehicles, but I know 94 and 95 4Runners don't list them.
If someone can prove me wrong, pleae do so as I'm interested to see if there are any door jamb stickers labeled w/ 31x10.50's.
Don't know if there's a similar trick on a pickup, but you can tell if a 2nd gen 4Runner came with 31's by looking at the way the spare tire lowers. If the crank handle has to go towards the driver's side then it had 31's, if it goes straight in, then it had 225s. Heh, usually the original spare is still under the truck too. That's a pretty easy way to tell <img src="/forums/images/graemlins/lol.gif" alt="" />
Hope that in some form or fashion helps
~R
...just realized someone already brought the tag issue up..oh well <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
94 4Runner 3.slow-5spd, 4" coils, 1.5" BJ spacers, 2" BL, 35x12.50 Nitto's, 5.29's with a front Lockrite and a rear Detroit; 250k miles and lots of offroad time...and by offroad I mean on jackstands.
Re: what gears are common in 90-95 4x4 ext cab pickups? [Re: Rusty Davis] #685147 01/21/06 05:41 AM
trythis Offline
The spare was a totally different size tire on mine, some kind of do-nut tire, but It was missing and I replaced it with a normal sized tire and wheel.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6259 MB (Peak: 0.7208 MB) Data Comp: Off Server Time: 2026-05-29 15:21:42 UTC
