Re: 3.2 DOHC Idle surge on startup
[Re: m_a_b]
#685232
01/20/06 07:32 AM
I had the O2 sensors replaced after the IMG as it was still setting off codes. No more codes but still have the surging.
[Re: ProBMXer1313]
#685233
01/22/06 05:05 AM
I had that problem (well still have but much more tamed now) and result to be the vacuum hose to the fuel regulator cut halfway, will give you full fuel pressure all the time, more fuel compsumption and the vacum leak mess up the tranny shift ritm, does it sounds familiar?
#685234
01/22/06 05:08 AM
Ya fixed that one too when I did all the other above mentioned stuff, broken line caused me to burn up 3 catalytic converters.
[Re: ProBMXer1313]
#685235
01/26/06 05:19 AM
Check IAC for proper function.
2002 Trooper S 5spd, cone filter, Ranchos, Modified for 2WL
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5989 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-06-15 10:24:22 UTCValid HTML 5 and Valid CSS
