brake fluid reservoir bobber #685238 01/12/06 04:07 AM
A
Andy_92563 Offline OP
I had my brakes flushed by a shop awhile back and did not really checked on their work; now I've noticed that they did not put back the "bobber thing" for the brake fluid reservoir. They just put the cap back on. What would that bobber do if I do not have it on the cap? Would it mess with my ABS??? I should have done it myself, but did not have the time that day, so I paid someone to screw it up!! Any info anyone. Thanks in advance.
-Andy
1999 Tacoma Black Limited V6, 4x4,104K,LEER shell cover, deck plate air box amsoil air/oil filters w/ amsoil fluids, bilsteins shocks front & rear
3" toytec coils & AAL, 4 new TOYO tires (31x10.5x15). selling truck to the right price!!
Re: brake fluid reservoir bobber [Re: Andy_92563] #685239 01/12/06 12:14 PM
Someone double check me, but is that "bobber" the float switch that turns on your brake light (idiot light on dash) when the fluid level gets too low? If yes, then I would definitely get that fixed asap! That idiot light saved my life once on an old truck when the master cylinder went bad and the fluid leaked out overnight on the first cold night of the year.
Re: brake fluid reservoir bobber [Re: Andy_92563] #685240 01/13/06 06:06 PM
Dandeman Offline
Toyota Moderator
Never read it anywhere, but I've always wondered if one purpose of the "bobber" was to cover the exposed surface area of the brake fluid, (which is very hydroscopic, meaning it absorbs water) to minimize moisture absorption rate into the brake fluid..
and, as mentioned above, the bobber turns on the low brake fluid light
Re: brake fluid reservoir bobber [Re: Dandeman] #685241 01/13/06 08:22 PM
A
No, my brake light is not on, but my ABS light is. I've called one toyota shop and they said it only levels the fluid when cornering so the brake light doesn't come on. It just annoys me that I pay someone to do a ***** job, I could have done the ***** job myself and shaved myself some money. <img src="/forums/images/graemlins/angry.gif" alt="" />
-Andy
Re: brake fluid reservoir bobber [Re: Andy_92563] #685242 01/14/06 03:50 AM
Dandeman Offline
Toyota Moderator
Kind of like years ago, I took my first Toyota to the Oldsmobile/Toyota <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> dealer in my little town to have the front wheel bearings repacked. Back then I wasn't into doing my own maintenance that much..
Saw the mechanic take my wheel bearings out, lay them on a dirty (and I'm sure gritty) concrete floor and then just add more grease and put them back in..
Brought it home pulled the bearings back out, cleaned all old grease (and grit the mechanic added) out with solvent and repacked.. Great motivator and major reason I started doing my own maintenance.
Re: brake fluid reservoir bobber [Re: Dandeman] #685243 01/23/06 09:25 PM
A
How do you repack the front wheel bearings? I spoke to a shop tech and they advised me that my truck is pressure sealed and cannot repack them. Is that true??? I wanted to do it my self. Is it hard?
-Andy
Re: brake fluid reservoir bobber [Re: Andy_92563] #685244 01/24/06 04:05 PM
Mark in AZ Offline
Toyota Moderator
It's true, no repacking needed.
Exploring in a T4R Ltd V8
Re: brake fluid reservoir bobber [Re: Mark in AZ] #685245 01/25/06 08:03 AM
4WD22R Offline
So it'd be pretty easy then huh? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: brake fluid reservoir bobber [Re: 4WD22R] #685246 01/25/06 03:40 PM
Mark in AZ Offline
Toyota Moderator
Yep, I don't charge to much for this valuable service <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: brake fluid reservoir bobber [Re: Mark in AZ] #685247 01/30/06 12:59 AM
A
thanks guys.
-Andy
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6286 MB (Peak: 0.7373 MB) Data Comp: Off Server Time: 2026-05-31 12:24:32 UTC
