Page 3 of 3 1 2 3
Re: Home mechanic alignment? #686059 01/17/06 06:18 PM
4WD22R Offline
Yeah, the Discount we have here tends to do good work, well, I DO know a couple people who work there, let's just say he gave me the "really good buddy" deal when I got my new BFG AT 31's: $432 out the door. With those cool screw in valve stems, and the lifetime free replacement warranty for all 4 <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Home mechanic alignment? [Re: 4WD22R] #686060 01/17/06 10:59 PM
Sweeeet deal! always good to have friends who work at places like that <img src="/forums/images/graemlins/kewl.gif" alt="" />
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Home mechanic alignment? [Re: elripster] #686061 01/18/06 08:13 PM
V
Voyager Offline OP
I think I am gettng this now. I didn't understand the caster implications before witht he cams pointing inward & outward, so I'm pretty sure they aren't matched.
One thing. The front cams wont go completely horizontal inward, for instance the driver side will either stop at 10 o'clock or 8 o'clock. Does bringing the cam down vs. up also adjust the caster? It seems like it changes the elevation.
I'm going to go at it again this weekend & see if I can get them about the same.
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: Home mechanic alignment? [Re: Voyager] #686062 01/18/06 10:52 PM
elripster Offline
They do tend to bind up a bit when you get to the max of the in/out adjustment but they will make it all the way, just need to apply more torque.
You wanna make sure they are close to symetrical. If the driver's side is at 10 o'clock, the passenger should be around 2 o'clock. Trust me, as long as both spindles are angling back, get the camber/toe right and don't worry about it.
When an alignment shop can't get the caster in spec, and on lifted trucks, prerunners especially, they rarely do, they just get the cross-caster close. Which, as said, means both spindles lean back as opposed to one forward and one back.
If you get the camber/toe in and cross caster as described, the truck should drive very very well.
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
Re: Home mechanic alignment? [Re: elripster] #686063 01/18/06 11:19 PM
V
Voyager Offline OP
Thanks Frank! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sid
Re: Home mechanic alignment? [Re: Voyager] #686064 01/18/06 11:39 PM
Well if you look at the lower control arm, you have 2 eccentric cams, 1 front and 1 rear. If you turn the rear one so it moves that bushing inwards and you turn the front so it moves that bushing outwards you now move the lower ball joint aft. then if you do the opposite you move the lower ball joint forward. This affects the caster setting, these 2 cam also adjust the camber by moving the front and rear lower control arm bushings in or out the same amount. you have to move the cam's in the right orientation to one another to get both the caster and camber set. <img src="/forums/images/graemlins/drunk.gif" alt="" />
You have to remember that the steering geometry is already designed into the front suspension, the adjustment eccentrics just allow for fine tuning as the rubber bushings settle and wear takes place and only take small adjustments to bring it back into spec's.
So as elripster mentioned if you can't get it into spec's with the eccentric's then something is badly worn or bent.
Discount tires got my 33's within factory spec's with room to spare.
If your having trouble turning the eccentrics you may have to pull each cam bolt and lightly grease just the bolt shaft and reassemble, but they are tough to turn especially when you have the weight of the vehicle on them, which is what you have to do. jacking up the wheels to make the adjustments is going to make it more difficult to get a stable reading.
I leave this kind of tedious work to the people that have the equipment to do the job.
Re: Home mechanic alignment? #686065 01/18/06 11:51 PM
V
Voyager Offline OP
Thanks.
Yea. Probably right. When I find who doens't have the "hog staring at a wristwatch" <img src="/forums/images/graemlins/zombie.gif" alt="" />expression when I pull my truck in, I may do just that. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sid
Re: Home mechanic alignment? [Re: Voyager] #686066 01/19/06 06:22 PM
elripster Offline
Part of what got me to align my own truck was two things. One, I did it on a custom hybrid we built at school and saw how easy it really was. Two, I have had bad luck with many alignment shops as I found the specs are pretty wide on our trucks and many techs simply don't do more than look for the red numbers to turn green.
As easy as it is to knock out alignment wheeling and as easy as it is to get it back in yourself, I enjoy the money savings. Hopefull you all can too!
Frank
www.sdori.com
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6284 MB (Peak: 0.7280 MB) Data Comp: Off Server Time: 2026-11-18 11:58:13 UTC
