Re: Home mechanic alignment?
[Re: 4Crawler]
#686049
01/16/06 08:15 PM
On IFS, no caster adjustment that I am aware of. If it is off, something is bent. On the IFS the caster is adjusted via the lower control arm eccentric cams (forward & rear) It's a fiddle to get both the caster and camber set. I watched the guy do mine at "discount tires", with the right equipment its a cake walk, but to do it any other way would be a tedious job. Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
#686050
01/16/06 09:33 PM
On the IFS the caster is adjusted via the lower control arm eccentric cams (forward & rear) Mmmm. So you are saying you saw a tech making verticle adjustments as well as horizontal with the front & rear cams on the lower control arm? I did notice each cam made a semicircle arc, but wasnt' really paying attention for verticle movement. That would change the caster I assume. I hope that is not true. If so that WOULD be the preverbial monkey balancing on the greased bowling ball adjustment and probably not within the realm of the home mechanic. <img src="/forums/images/graemlins/frown.gif" alt="" />
Sid
89 extra cab 4x4 3.0 5 spd, 216K 4.56, Supra LSD, Lock Rite
[Re: Voyager]
#686051
01/17/06 01:03 AM
When you are adjusting the camber, the caster is usually changing too. What's important is the cross caster isn't too far off. You want both spindles leaning backwards somewhat as opposed to one forwards and one backwards. However, camber is much more important than caster. If you get the camber and toe right with both spindles leaning back, you are good to go. The truck will drive great. An alignment shop would do no different.
For example, the front lower cams should be pointing inwards while each rear pointing outwards. This moves the lower a-arm forwards not only angling the spindles as they should be but also increasing the clearance between the wheels and firewall which is nice.
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos. www.sdori.com
[Re: Voyager]
#686052
01/17/06 06:47 AM
I hope that is not true. If so that WOULD be the preverbial monkey balancing on the greased bowling ball adjustment and probably not within the realm of the home mechanic. <img src="/forums/images/graemlins/frown.gif" alt="" /> Yes, by adjusting the lower control arm bushing eccentrics, you adjust caster and chamber. Turning the eccentrics in the same direction equally either clockwise or counter clockwise will move the lower ball joint in or out effecting the chamber setting. Turning the eccentric cams in opposite directions one clockwise the other counter clockwise or vise versa will move the lower ball joint fore and aft effecting the caster setting. The trick is to get the chamber and caster set, both by manipulating the eccentrics cams. With professional alignment equipment makes it an easy task to set both the camber/caster at the same time, But to do it with conventional means using a cheap simple alignment gauge that attaches to the wheel and then attempting to set the caster then the chamber separately is a tricky thing to do and making the right choice on which adjustment to manipulate to bring the camber readings into spec's while maintaining the caster setting is going to be a long trial and error task. This is why they use wheel alignment tables so they can view caster, chamber, toe, thrust, and cross camber all reasonably easily. Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
#686053
01/17/06 07:40 AM
It's a fiddle to get both the caster and camber set. I watched the guy do mine at "discount tires", with the right equipment its a cake walk, but to do it any other way would be a tedious job. Disconnt does alignments? since when? Must be a Cali thing.....none of them around here do, and I have friends that work there.
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: 4WD22R]
#686054
01/17/06 07:48 AM
Disconnt does alignments? since when? Must be a Cali thing.....none of them around here do, and I have friends that work there Yes, the one I went to had the computer 4 wheel alignments table. I haven't seen a tire shop out here that didn't have or offer wheel alignments. Discount Tire Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
#686055
01/17/06 08:06 AM
Ah....you have a different discount tire Discount Tire
[Re: 4WD22R]
#686056
01/17/06 08:17 AM
Ok, yeah 2 different companies with similar names. I can't imagine a tire shop selling tires without offering wheel alignment, which is required in order to get proper warranty coverage, I would think anyway.
Chuck MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
#686057
01/17/06 08:21 AM
they balance, not align, come to think of it, I don't think Cost Co does, neither does Big O.....I don't know of the others for sure.
[Re: 4WD22R]
#686058
01/17/06 08:52 AM
Not sure about Big O-Tire either, I stumbled across Discount tire center (or more like forced to) when I ran over some debris on the HYW and punctured one tire and cut up the side wall on another. They seem to do decent work!
