Rear transfer case output seal. #686106 01/14/06 08:40 PM
F
FarmerTed Offline OP
How hard is it to change the rear transfer case output seal? Mine is seeping a little bit. I'm changing the u-joints today so I'll already be in there.
1994 4x4 22RE
Re: Rear transfer case output seal. [Re: FarmerTed] #686107 01/14/06 10:03 PM
4Crawler Offline
VEry easy, see the following page for pinion seal replacement, essentially the same thing, just no worries about pinion bearing preload, etc.:
http://www.4crawler.com/4x4/CheapTricks/PinionSeal/index.html
Only other tip is to apply a bit of silicone to the splines before reinstalling the flange to seal up that area.
Re: Rear transfer case output seal. [Re: 4Crawler] #686108 01/15/06 12:10 AM
SHAD Offline
30 mm impact socket and a 1/2 cordless impact makes short work of it. A seal puller tends to help more than the screw driver method to remove it.
Definately recommend getting one.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: Rear transfer case output seal. [Re: SHAD] #686109 01/15/06 01:03 AM
F
Sounds easy enough. Is it also 90 ft lbs torque?
1994 4x4 22RE
Re: Rear transfer case output seal. [Re: FarmerTed] #686110 01/15/06 01:15 AM
4Crawler Offline
I think the FSM calls for 90 ft.lbs. That is usually what I use. Short of stripping the threads on the output shaft, you probably can't have it too tight, within reason. I know when I first removed mine (to redrill the flange) after having it built by Marlin, I needed a 4' pipe over a breaker bar on the nut and a similar bar bolted to the flange to keep it from turning to just barely get it loose. This was after two different 1/2" impacts failed to get it loose. I say I just barely got it off because the pipe on the breaker bar was bending under the torque to the point it was bent from the frame to the ground before the nut finally gave way. I'm thinking Marlin may have used his special impact gun when he put that t-case together <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6046 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-06-19 23:25:30 UTC
