4.2 block #686374 01/15/06 08:40 PM
bill_grinder Offline OP
I have an 86 cj-7 with 258(4.2). It has a knock. I also have a 258 from an 80 cj-5. I notice the heads are different, are the blocks the same? Thanks.
Re: 4.2 block [Re: bill_grinder] #686375 01/15/06 09:31 PM
TX4wl Offline
yes
Re: 4.2 block [Re: bill_grinder] #686376 01/15/06 11:20 PM
JeePete Offline
Depending when the blocks were made (not necessarily the model year) they could have different sized head bolts. If your 80 engine was made in 79 it should have 1/2 inch head bolts. Likewise, if your 86 was made in 85 it should have 7/16 bolts. The engine in my 86 CJ was made in 84 and has 7/16 bolts in 86 they went back to 1/2 inch. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 4.2 block [Re: bill_grinder] #686377 01/16/06 12:06 AM
BigJim Offline
Both of the above posts are factual! The big problem is always getting the correct valve COVER when changing heads. Make sure you have one that fits the head you intend to use before installing a 4.2 head.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5982 MB (Peak: 0.6531 MB) Data Comp: Off Server Time: 2026-06-21 03:35:52 UTC
