Page 1 of 3 1 2 3
Crankshaft pulley problems & MORE!-help requested #686644 01/16/06 08:41 PM
Mulerider Offline OP
Newbie here; I posted back in mid-Dec that my recently acquired 88 Trooper had suffered from crankshaft pulley failure. Lots of sudden noise, and you could turn and move around the pulley by hand.
Got the part from Jerry Lemond, and finally today pulled the fan and radiator.
What was under the fan shroud? The crankshaft bolt! Boogered threads, maybe but not likely usable. Whut happened..
It get worse; the rubber portion of the balancer had not come apart, instead the pulley had broken, leaving a portion on the crank. As the bulk of it came off (I'm guessing here..), it clipped the cambelt sprocket, removing a 1-1/2x1/2" chunk.
That must have happened as I started and drove the crippled thing onto the trailer, as then it went to "no-start" mode trying to unload it.
Cambelt got broke in the process. So....assuming I get off the remainder of the crank pulley, then pull (?) off the cambelt sprocket..geez <img src="/forums/images/graemlins/frown.gif" alt="" />
So I need: crank bolt, cambelt sprocket, and do a search here for sprocket/belt alignment.
So much for using the starter technique for crank bolt removal....my Trooper did it for me!
I think I saved Jerry's e-mail and phone #.
Thanks in advance for any tips or feedback...I'm working w/o a manual, just this site for help.
Added: just ordered the Haynes manual...I think I'll need it.
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686645 01/16/06 11:08 PM
dvtrooper Offline
Mulerider, sorry to hear about your bad luck i will look around my garage i have some spare engine parts, i will let you know if i find what you need. Don
sua dana 44 conversion 5.38 gears, 4.3tbi,700r,dana 300 w/tera low 4:1 gears
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686646 01/16/06 11:35 PM
litnin Offline
You might want to be prepared to check some valves.
If the belt broke while the engine was running,
there's a good change you bent some valves.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Crankshaft pulley problems & MORE!-help requested [Re: litnin] #686647 01/17/06 12:16 AM
There is enough left of the timing belt sprocket to put a puller on it; it is just pressed on?
And the crankshaft key looks really bad, so that's another issue.
Why for did Isuzu run a transmission line (looks like trans oil...) across the front? Drip,drip, drip.....
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686648 01/17/06 12:32 AM
randii Offline
That's a power-steering 'cooler' line.
Randii
Re: Crankshaft pulley problems & MORE!-help requested [Re: randii] #686649 01/17/06 01:58 AM
Happy Birthday mlclark Offline
Isuzu Moderator
No, that is the PS pump supply line. The cooler loop is down below on the rad support. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Crankshaft pulley problems & MORE!-help requested [Re: mlclark] #686650 01/17/06 02:21 AM
"No, that is the PS pump supply line. The cooler loop is down below on the rad support.
Michael"
Oops...as soon as I was back at the Trooper, the line was easily seen going to the power steering pump.
Back to my real concern....
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686651 01/17/06 03:32 AM
Isuzu Moderator
Oops...
You made no mistake. Randii, OTOH, did. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
Re: Crankshaft pulley problems & MORE!-help requested [Re: mlclark] #686652 01/17/06 06:00 AM
randii Offline
It happens. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Randii (mine is a cooler now)
Re: Crankshaft pulley problems & MORE!-help requested [Re: randii] #686653 01/17/06 02:48 PM
"There is enough left of the timing belt sprocket to put a puller on it; it is just pressed on?"
Anyone had to remove/replace the sprocket?
`88 Trooper 2.6L
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6379 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-11-18 22:38:10 UTC
