Page 2 of 3 1 2 3
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686654 01/17/06 03:04 PM
I
islandracer Offline
Not pressed on, it's held in there by the crank bolt. The crank has a woodruf key. My guess is if it's hard as hell to remove, it might be wedged in there...
B.Y.E. ~ Back Yard Engineering
Re: Crankshaft pulley problems & MORE!-help requested [Re: islandracer] #686655 01/18/06 07:18 AM
pucci Offline
it's also a very precise fit - I didn't have a puller but was able to work mine off after a PB soak, some gentle prying and a lot of cussing.
2.6 Trooper
2.0 Impulse Turbo
Re: Crankshaft pulley problems & MORE!-help requested [Re: pucci] #686656 01/18/06 07:35 AM
Happy Birthday mlclark Offline
Isuzu Moderator
Just to toss one more opinion into the abyss, the crank sprocket is not a press fit. It should slide off by hand. There may be a bit of rust/corrosion, but not much. I've never had to use anything but my hand.
If it got hit hard enough to break it, it may be buggered. Although, I am kind of confused to how the crank pulley broke it. The sprocket is rather protected behind everything. Not that it is impossible, but just hard to visualize.
Good Luck,
Michael
Re: Crankshaft pulley problems & MORE!-help requested [Re: mlclark] #686657 01/18/06 02:55 PM
Mulerider Offline OP
I'm guessing the sequence may have been:
1-crankbolt backs out over time
2-crank pulley walks out slowly (crank key looks like sh**)?
3-crank pulley breaks apart (from the backside)
4-wobbling remnants of pulley and pieces conspire to take out a chunk of belt sprocket and cut the belt.
I had to pry a piece of the pulley out of the plastic belt cover. It got imbedded at some point in this mess.
Thanks for the help, and I hope to finish disassemly tonight.
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686658 01/18/06 03:32 PM
I
islandracer Offline
I'm wondering if the problem started from bad thrust washers? Maybe? IDK? <img src="/forums/images/graemlins/frown.gif" alt="" />
In any case, you could try cold chiselling it off or use a die grinder with a cutting wheel... Hope your crank did not suffer any damage.
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686659 01/19/06 04:55 PM
dvtrooper Offline
Mulerider, if you need the lower crank gear and crank bolt and the pulley that bolts to the harmonic balancer, if you want it just let me know. Don
sua dana 44 conversion 5.38 gears, 4.3tbi,700r,dana 300 w/tera low 4:1 gears
Re: Crankshaft pulley problems & MORE!-help requested [Re: dvtrooper] #686660 01/19/06 07:05 PM
Thanks for the generous offer. E-mail sent with particulars.
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686661 01/22/06 11:07 PM
Greetings All
I am the cornfused new 1st time owner of a 91 Trooper with a 2.6 and a blown head gasket (runs but pumps water into the oil). Struggling to get the head off to see what gives (gave) but cannot get the crankshaft pully off. Sorry to hijack this thread but it seems like ya'll might know. I haven't taken one off before. The manual(Chilton) doesnt explain how, just says "remove pulley". I see three holes in the pulley and suspect that a tool attaches there to stop the thing from turning, or it could be some sort of balancing thing? Apologies to the seasoned mechanics to be asking such a simple question here. But the formentioned horrors of a failed pulley have me runnin scared to get educated before I get medieval on the thing. Are the threads normal (not backwards?) Thanks and apologies if my question on someone elses thread is out of line.... <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Crankshaft pulley problems & MORE!-help requested #686662 01/22/06 11:21 PM
Isuzu Moderator
Dave-
You need a harmonic balancer puller. It looks like this:
You will need two or three longer bolts that screw into the spots you saw. They may or may not be in the kit you buy.
Once it is bolted up, the center part pushes on the crank and pulles the pulley off. Pretty simple.
Good Luck,
Michael
Re: Crankshaft pulley problems & MORE!-help requested [Re: mlclark] #686663 01/23/06 12:02 AM
Awsome! (this is my 1st time using such a resource, being a non-tecno-sapien). But I em even more ignorant than that, I dont even have the bolt out yet. When I lean on the wrench (Dad's trusty 1/2 inch drive Craftsman rachet, non pneumatic garage hacker here) the engine turns over, (the manual says it must remain at top dead center, I tried stickin it in 1st gear but it still moves). I will be removing the timing belt to access the head. If I am too green for this website (most people seem to know a lot more than me) please let me know. Otherwise, I sure do appreciate the help! D
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 1.552s Queries: 16 (0.011s) Memory: 0.6382 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-11-18 23:56:18 UTC
