Page 3 of 3 1 2 3
Re: Crankshaft pulley problems & MORE!-help requested #686664 01/23/06 01:28 AM
Troopersphere Offline
Hey Dave, welcome... try puttin' the rig in 5th gear, parking brake engaged tightly (and maybe chock the wheels if necessary). Give some mighty pulls on the wrench and it should come loose. It's normal thread, righty tighty, lefty loosey. If it don't budge, others will tell you how to get it off by bumping the starter with the wrench wedged against the frame, but I've never had to do it that way.
The several times I've dont it, I haven't needed the puller, just wiggled it and it came right off.
Check out the search feature, remember to set the date range or you won't get many results, there's lots of info on doing the head job you are doing. One in particular is a post quite a while ago by RufusTheRam . Try searching on that username and see what you get... It was maybe 2 years ago.
Click Here, I found it for ya...
Good Luck!
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Crankshaft pulley problems & MORE!-help requested [Re: Troopersphere] #686665 01/23/06 06:29 AM
Thanks mister. In that thread you provided it looks like he's managed to change the head gasket without removing the crankshaft pulley so I am looking at this possibility before I try your suggestion. Its fantastic how much more read-able and specific the information provided here by the guys that are actually into the car as a hobby compared with the dry small wording in the old library Chiltron's Manual. Thanks to everyone who lends there experiences here, D <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Crankshaft pulley problems & MORE!-help requested #686666 01/23/06 06:43 AM
If you aren't sure when the timing belt was last changed, now is a real good time to do it! 60K miles is the factory recommended interval. It's really not that much more work, and you'd be pretty P.O.ed if you did the head gasket, and the belt broke 10K miles later! <img src="/forums/images/graemlins/shiner.gif" alt="" />
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Crankshaft pulley problems & MORE!-help requested [Re: Troopersphere] #686667 01/23/06 07:33 AM
Very Well. It looks pretty fresh. But yes, you are right. I will yank it out and compare it to a new one and see if its still good. I can see that someone was in there fairly recently and changed out some hoses and probabaly did this head gasket that I am replacing now. I will be taking it up to extremely cold mountain climates this winter. I suppose that could contribute to rubber degredation. Any thoughts out there on making this head gasket stay intact? ('91 2.6L Trooper, all stock)
Re: Crankshaft pulley problems & MORE!-help requested #686668 01/24/06 03:55 AM
Don_W Offline
Gentlemen,
For what it's worth, at 90K my timing belt looked almost new. I think the key is to replace it BEFORE signs of wear. The other thing I've read frequently here is that while you are doing all that, have a look at the water pump...
Don
1989 Trooper II 2.6L
222,222
Re: Crankshaft pulley problems & MORE!-help requested [Re: Don_W] #686669 03/18/06 09:16 PM
Mulerider Offline OP
For many reasons my broke Trooper was ignored till today...when I last attempted repair, the broken timing gear refused to budge from the crank, for reasons unknown.
Today, using a different puller, all I managed was to break the remaining flange off of the sprocket ( yet the gear SHOULD just slide off).
Next was the Dremel tool; I cut a substantial groove in the gear, then used a chisel to successfully break off the gear..yeah!!
The key under the gear looks okay ( not much there)...the rest of the key (where the pully rides) is virtually gone.
It needs replacing...is it removable??? I just can't tell with what I have to see.
Clamping onto the good portion of the key with ViseGrips, then tapping upwards with a hammer yielded nothing.
Trying to catch the edge of the key on the nose of the crank also got me nowhere, but I will try that route again.
There just is not enough key left to properly hold the pulley..aagghh.
Any help is greatly appreciated.
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686670 03/19/06 08:28 PM
Happy Birthday mlclark Offline
Isuzu Moderator
I know we can tell you something "should" behave in some manner only so many times, but that key "should" pop out on its own with very little effort. I would drive it rearward with some considerable force. The keyway is ramped towards the back and it "should" force it out.
I'm still trying to figure out how this happened. It is not normal to sheer off a hardened key. Like, really really not normal. I would be worried about several things. 1) The keyway is hosed. 2) the crank snout is hosed where the pulley spun around on it, with that piece of hardened key in it. Either of those are bad.
I would suspect that the pulley bolt backed out enough to allow for the pulley to rattle around enough to destroy the key. When everything spun, it succeed in tearing itself the rest of the way apart.
Get the key out and see what you are working with. If the crank is damaged, the ultimate answer it to replace it. There is not much you can do in the way of repair. Or, any repair will exceed the cost of a crank.
That said, if you can clean it up enough for the timing gear to slide on and off with little effort and you can get a key to sit in the keyway there are a few things that I would be comfortable doing. Remember, this is one of those suggestions that is almost last ditch. We are talking fixing it or scrapping the vehicle here. Since this vehicle is 20+ years old, the level for scrapping starts to get pretty low.
I would consider some nice red locktite to hold the key in place (if there is play) and tighten it all down to the proper torque. Make sure the bolt is good and the threads in the crank are good. Keep any locktite off the crank, or it will never come apart again.
Good Luck,
Michael
Re: Crankshaft pulley problems & MORE!-help requested [Re: mlclark] #686671 03/20/06 04:52 AM
Michael: thanks for the words of encouragement, and I will continue in my "key removal" quest.
The key (forward of the timing gear) is extremely "rounded" off...not gone, but definitely not enough to properly grip the new pulley.
The crank nose looks okay, no galling or wear noted.
DV Trooper supplied me with another bolt and timing gear, so that's covered. After I get the key out (thinking positive), there will be Loctite used in re-assembly!
I have not verified thru research or otherwise if the `88 2.6 has piston/valve relief clearance, but I sure hope so!
Re: Crankshaft pulley problems & MORE!-help requested [Re: Mulerider] #686672 03/20/06 05:26 AM
Isuzu Moderator
No. But your cam to crank relationship did not change. Just the crank pulley's relationship to the rest of the world changed.
Michael
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6337 MB (Peak: 0.7518 MB) Data Comp: Off Server Time: 2026-11-18 23:55:24 UTC
