Wire that is Hot when ignition is on for wiring in my radar detector? #686679 01/16/06 09:06 PM
Squeezer99 Offline OP
on my 95 T100, what would be a good wire to wire my radar detector into so that it will have power when I start my T100? The wires supplied by Valentine 1 already have inline fuses. I was thinking either cigarette lighter or the ignition power wire for the radio. Are either one of those fine or should I be looking at some other wire?
Re: Wire that is Hot when ignition is on for wiring in my radar detector? [Re: Squeezer99] #686680 01/16/06 09:44 PM
Jake97T Offline
How do you wire it in, did you cut the cig. plug off and expose the ground and power? Ive been considering doing the same thing on my radar detector, let me know what you come up with,
Ive been thinking of splicing directly into the power on the cig lighter wires behind the panel...
Re: Wire that is Hot when ignition is on for wiring in my radar detector? [Re: Jake97T] #686681 01/16/06 10:06 PM
95T100 Offline
I have used the wire going to the cig lighter in the past. If you have any high drain items, use that wire to trip a relay. Easiest wire to get to.
1995 Toyota T100, Rhino Liner, SwayAway Torsion Bars, Bilestien Shocks, Brembo Rotors, Akebono Pads, SS Brakelines, Monroe Steering Stabilizer & TRD/Eaton LSD
Re: Wire that is Hot when ignition is on for wiring in my radar detector? [Re: Jake97T] #686682 01/16/06 10:38 PM
I'm going to use a T-tap connector on a positive wire that comes on when the ignition is on and find a nearby screw that is gounded. then run the wires under the dash and up the side piller trim, tuck the wire between the windshield and headliner and have just a few inches hanging out that plugs into the radar detector
Re: Wire that is Hot when ignition is on for wiring in my radar detector? [Re: Squeezer99] #686683 01/17/06 01:41 AM
garym Offline
What size fuses are in the radar detector?
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Wire that is Hot when ignition is on for wiring in my radar detector? [Re: garym] #686684 01/17/06 04:31 PM
Jake97T Offline
Mine has what looks like a 5 amp or less on it...very very small fuse, less than 1/2 inch long
Re: Wire that is Hot when ignition is on for wiring in my radar detector? [Re: Jake97T] #686685 01/18/06 05:33 PM
garym Offline
As long as it draws under 5 amps (probably less than 3 as the fuse should be about 2X the draw)you should be good to hook it into the ign circuit. You just don't want to hook anything that draws a lot of current. The ign. sw. wasn't really designed to handle big loads and the contacts will eventually burn up with a high draw. That is when you go to a switching relay.
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6104 MB (Peak: 0.6879 MB) Data Comp: Off Server Time: 2026-06-09 19:06:51 UTC
