electric fan question #686842 01/17/06 06:14 AM
L
lookmomnobrains Offline OP
im about to order a rad fan to replace that damn clutched p.o.s. on my 22r. how many cfm is needed to cool sufficiently? jegs has all kinds.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: electric fan question [Re: lookmomnobrains] #686843 01/17/06 06:23 AM
half_fast Offline
Why electric? I have a 14 inch electric but only so I can turn it off when mudding. It wont cool any better, and probably worse since you wont have a shroud. Also, my fan blade and shroud was broke and it would have cost just as much to replace them through Toyota as it was for the electric fan conversion.
over heating problems are most probably caused by a bad head gasket, clogged radiator, or a bad water pump.
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: electric fan question [Re: half_fast] #686844 01/17/06 06:36 AM
L
im just sick of replacing clutches. im not overheating. they dont like it when you rev your motor to hell. they end up dead or stuck on. ive been through 2 in the last year. and i like the ability to choose when the fan kicks on.
Re: electric fan question [Re: lookmomnobrains] #686845 01/17/06 06:50 AM
4Crawler Offline
I used to run the Flex-a-lite, I think it was rated 2800 CFM. Did not cool quite as well as the stock fan clutch, but was sufficient. Here are the FAL fan specs:
http://www.flex-a-lite.com/auto/html/toyota-4x4.html
On the fan clutches, I have found the Aisin part from the dealer are 10X better than the no-name parts you get elsewhere. I had one from NAPA puke all the silicone oil out all over the engine after less than 1 year's use. Still trying to clean that oil off the underside of the hood. Even after 7 years, dust will stick to the places that silicone oil splattered.
Re: electric fan question [Re: 4Crawler] #686846 01/17/06 06:54 AM
L
wow 2800? i was looking at this: http://www.jegs.com/webapp/wcs/stor...egoryId=24285&searchItemId=96715
if 2800 didnt work this wont have a hope in hell. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: electric fan question [Re: 4Crawler] #686847 01/17/06 06:56 AM
willzrunna96 Offline
just curious how do you know your clutch is bad. i can hear my fan and then sometimes i cant, its kinda driving me nuts. i priced one at the zone today and its 40 bucks lifetime warranty
Re: electric fan question [Re: willzrunna96] #686848 01/17/06 07:02 AM
4Crawler Offline
Re: electric fan question [Re: lookmomnobrains] #686849 01/17/06 07:03 AM
BennyBoy Offline
If you've got a three row? than a lower power fan will work. A german fan from the junkyard will work.
I have a BlackMagic but its overkill and cost close to $200. It only comes on in heavy traffic and almost never in the winter times.
Re: electric fan question [Re: willzrunna96] #686850 01/17/06 07:04 AM
L
in my case i will stop at a light and sit for 30 seconds. at takeoff it will spin up then fade out. now progressively it is staying on more and more. its on all the time now. i know im not overheating. it has happened to me where the fan never kicks on which can be much worse.
Re: electric fan question [Re: lookmomnobrains] #686851 01/19/06 09:22 PM
dcg9381 Offline
I run a 3 core radiator and a 16" fan. If you get wet or mud, make sure it's switched. Has to be a fairly thin fan, however..
I've seen the temperature controlled mechanisms fail time and again, I will no longer run one. Just run a good sized 30A relay.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6411 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-06-13 02:05:15 UTC
