Page 3 of 3 1 2 3
Re: Transfer Twin Sticks, What's the Best? [Re: Andy] #687449 01/20/06 11:26 PM
4Crawler Offline
I think the issue on those trans/t-cases is that the trans and t-case shifters share a common base plate. So instead of having two separate shifter bases, there is one with both holes in it. As such, you can not replace just the t-case shifter by itself.
Re: Transfer Twin Sticks, What's the Best? [Re: DirtyHarry] #687450 01/21/06 12:28 AM
Red_Chili Offline
Toyota Section Staffer
Loud buzz, minor buzz, did you try to dampen the buzz? I'm running BFG MT's and the road noise is macho loud, plus that NV4500's gear set isn't whisper quiet either.
At Chili Man's recommendation I put a wavy washer between the sticks on my FROR twin stick. Unfortunately I cannot tell you if this has helped at highway speeds or not. <img src="/forums/images/graemlins/frown.gif" alt="" />
Ya know, there's a cure for that there problemo!
-Bill
Re: Transfer Twin Sticks, What's the Best? #687451 01/21/06 01:39 AM
keep in mind that none of the twin sticks on the market are designed to work with a single t-case.
the straight up shifters will interfere with the transmission shifter.
i had to make one with funky bends in the handle to clear the transmission shifter
marlin sells a twin stick for a forward shift g54!
Re: Transfer Twin Sticks, What's the Best? #687452 01/21/06 03:56 AM
D-runner Offline
That may be true if your running a forward shift t-case. I have a W-56B with a top shift t-case and have no interferance problems with the transmission shifter.
whose twin stick do you have? i have a w-56 and a top shift as well.
I have ran both but now have Marlin's.
There are 4 different W-56 trans. A & B have top shift t-cases and C & D have forward shift t-cases.
Adam W.
87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6049 MB (Peak: 0.6636 MB) Data Comp: Off Server Time: 2026-06-13 10:56:05 UTC
