Re: Transfer Twin Sticks, What's the Best?
[Re: bkg]
#687439
01/20/06 05:57 AM
Plus it is another gadget to have. <img src="/forums/images/graemlins/smile.gif" alt="" />
Truth! <img src="/forums/images/graemlins/lol.gif" alt="" /> Looks cool all your friends will have to get one too! <img src="/forums/images/graemlins/nana.gif" alt="" />[/quote]
#687440
01/20/06 06:57 AM
Truth! <img src="/forums/images/graemlins/lol.gif" alt="" /> Looks cool all your friends will have to get one too! <img src="/forums/images/graemlins/nana.gif" alt="" /> That combined with dual t-cases and a manual is sure to impress anyone who takes a ride with you....."You have 4 SHIFTERS!!! what the f*** for!!!!" <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: 4WD22R]
#687441
01/20/06 03:10 PM
keep in mind that none of the twin sticks on the market are designed to work with a single t-case.
the straight up shifters will interfere with the transmission shifter.
i had to make one with funky bends in the handle to clear the transmission shifter
#687442
01/20/06 03:39 PM
i had to make one with funky bends in the handle to clear the transmission shifter When I read your first sentence I wanted to cry foul, but you are 100% correct about shifter interference. Good call. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Brian K. Gallus I have nothing important to say.
[Re: bkg]
#687443
01/20/06 04:54 PM
Toyota Section Staffer
And not hard to do with a MAPP gas torch. Just make sure no plastic parts are still attached. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
For most of us it's a gadget. Kinda like when I want the car salesman to go away and leave me alone when I stop to get parts: "Hey, don't you want to get a newer truck? We've got some great new trucks, bet you've got a lot of miles on that one." "Why would I? Solid axle, 3.4, lockers F&R, ..... , blah, blah, blah, 20 forward speeds, 4 reverse, take a look inside."
He glazes over right about then. Mission accomplished.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#687444
01/20/06 06:50 PM
So, this buzzing has me a little concerned, I'm told they DO NOT want me to be any more nuts than I already am.<img src="/forums/images/graemlins/cyclops.gif" alt="" />
Loud buzz, minor buzz, did you try to dampen the buzz? I'm running BFG MT's and the road noise is macho loud, plus that NV4500's gear set isn't whisper quiet either.
If the twin sticks interfere with the transmission shifter, I'll make the necessary adjustments.<img src="/forums/images/graemlins/notooth.gif" alt="" />
Real fun takes hard work. '83 Short bed, NV4500, 33" BFG MT
#687445
01/20/06 08:07 PM
i had to make one with funky bends in the handle to clear the transmission shifter That may be true if your running a forward shift t-case. I have a W-56B with a top shift t-case and have no interferance problems with the transmission shifter. Andy - As for the buzzing sound, it no problem if your driving around town but out on the freeway for an hour and you will go nuts. <img src="/forums/images/graemlins/zombie.gif" alt="" /> When Marlin rebuilt my trans, I asked him about the shifter noise and thats when he showed me the twin sticks that he sells and said that it would be quiet. It has been for the last 3 years. Chili Man - Don't forget to show them the FF rear axle. Drove my parts man crazy when I told him that I have manual locking hubs on the rear and LC brake parts.
Adam W. 87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
[Re: Andy]
#687446
01/20/06 08:17 PM
Toyota Moderator
At Chili Man's recommendation I put a wavy washer between the sticks on my FROR twin stick. Unfortunately I cannot tell you if this has helped at highway speeds or not. <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: D-runner]
#687447
01/20/06 10:39 PM
whose twin stick do you have? i have a w-56 and a top shift as well. for reference,here is the one i made: ![[Linked Image]](http://web.missouri.edu/~pje3k5/sas/twinstick.JPG)
#687448
01/20/06 11:06 PM
I took this quote from Marlin's site:
"Twin shifters can not be used on a single transfer case behind a W56 C or D model transmission but can be used on the rear case of a dual case setup on these transmissions."
I suppose this is because of transmission shifter interference. Apparently A and B versions are OK. I don't have a W56, but am curious as to how many W56 versions there are.
I like the curves, Napoleon!
