Page 3 of 3 1 2 3
Re: SAS questions [Re: eightyeight] #687808 01/20/06 07:38 PM
DirtyHarry Offline
Toyota Moderator
any comments on this:
Trail-Gear SAS
I think that it looks like a copy of Marlin's SAS kit, which was a copy of All-Pro's SAS kit. Until I see something original come out from Trail Gear that command the same respect from me at Sky Mfg does.
Speaking of which, the problem with his hanger is that it is C-channel, not boxed. If that isn't a recipe for disaster I don't know what is.
Re: SAS questions [Re: DirtyHarry] #687809 01/21/06 02:43 AM
Brian894X4 Offline
Trail-Gear SAS
When it comes to the front hanger, there's only so much you can make different. The difference is in the details.
All Pro seems to use a big square tubing than either Marlin or Wally-Gear to tie the two spring hangers together, which is probably stronger in that area. Also, A/P seems to be the only one using the bolt hole method to line up the front spring hanger to the front cross member. And A/P does have a tiny extra gusset that I don't see on the others. All three are well gussetted at the spring hanger itself, which I like.
The thing I don't really like about FRORF's hanger is the lack of gussetting at the hangers. It's probably the cheapest design to manufacture, too. Although he does include front brace brackets as addition gussetts to weld for the front hanger that others don't. And his hangers are 1/4" steel. Not sure about the others. I do like the fact that FRORF seems to be the only one who at least addressed the difference between IFS and SA trucks as far as front crossmember hieght and how that affects the over all lift.
Sky's is a wierd design that looked like they made it mainly for advertisement. They probably wanted to use a flat piece of steel that they could stamp out their name, then roll into a C-channel and weld hangers too. It's probably hard to stamp in their name on a piece of square tubing. I don't really like the design, either.
Now that I look at all the hangers again, I can't really figure out how one gives more or less lift than the others. They're all basicly the same design as far just shackle hangers with some kind of brace in between. The hieght differences between the top of the shackle hanger the bolt hole can't be more than a 1/2" different between any of them. And is probably less than that.
Re: SAS questions [Re: Brian894X4] #687810 01/21/06 04:31 AM
bkg Offline
Actually, AP's doesn't have a little gusset, they don't use tube for the spring hangers themselves anymore. It's a two piece design of flat 1/4" bent into a puzzle and welded together. Kind of cool, really, and much stronger than ttheir original design.
The fact that Brian includes the 4 gussets is key; the others don't. Keep in mind also, his is 1" less drop than the others, so less leverage.
Agreed.
Brian's is 1" less drop than the rest. Running it on mine, reversed and flush with the front of the FRORF-frame brace. So 1.25" forward of stock. Works great - for a vechile that never wheels. <img src="/forums/images/graemlins/smile.gif" alt="" />
Brian K. Gallus
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6070 MB (Peak: 0.6791 MB) Data Comp: Off Server Time: 2026-11-02 04:01:13 UTC
