Re: 05 Tacoma Headlights [Re: Chris_Tacoma] #687888 01/26/06 09:13 PM
I did a search and found no results. Has anyone with the 05/06 or any newer model year Tacoma had problems with the brightness of their headlights? The reason i ask is that while driving at nights i have people who flash their high beams on and off at me while we approach one another. People must think my high beams are on and are trying to tell me by flashing their high beams at me, so in return i do a brief on/off with my high beams to show them i am driving with my low beams on. <img src="/forums/images/graemlins/scared.gif" alt="" /> Anyone else have this problem? Any ideas on how to correct this with out having to go to a stealership. I have changed my headlight bulbs to ones with the blue tint to them, thinking this would help on the eyes of passing motorists. Any and all help is appreciated.
Chris
At the back of the headlight assembly(lift the hood) you should see some adjustment knobs, you may need a small spanner to adjust them, drive your vehicle up to a wall, square on and about 10 feet away at night, now just adjust the lights down so that thay are about 3-4 inches lower than where they are aimed now, then see how you go with oncoming cars, also those blue light bulbs, hopeless in the wet at night, you'll think you have no lights on
Kev
Re: 05 Tacoma Headlights [Re: kuso] #687889 01/27/06 06:25 AM
BIGBURLYNAKEDMAN Offline
I put two 250's (a YZ and a CR, both 2-strokes) with gear and firewood in mine on a regular basis and she does just fine (although, as I said earlier it's pretty low in the back). My truck is supercharged, so I don't notice too much lack of power even with all that weight. One time I somehow fit in the two 250's AND a CR 80 (facing backwards <img src="/forums/images/graemlins/smile.gif" alt="" />)! No complaints here.
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: 05 Tacoma Headlights #687890 01/28/06 05:38 PM
Chris_Tacoma Offline OP
At the back of the headlight assembly(lift the hood) you should see some adjustment knobs, you may need a small spanner to adjust them, drive your vehicle up to a wall, square on and about 10 feet away at night, now just adjust the lights down so that they are about 3-4 inches lower than where they are aimed now, then see how you go with oncoming cars, also those blue light bulbs, hopeless in the wet at night, you'll think you have no lights on
Kev
Thanks Kev, I did like you suggested. I did adjust the headlights down. Wasn't difficult at all. Yes the bulbs with the blue tint to them are bad in the rain at night. I thought it was just my eyes. I will use these blue tinted bulbs until they burn out then put my originals back in, if i don't change them before that. Thanks for your help.
Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
05 Tacoma Extra Cab
The Reaper Is My Copilot
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5992 MB (Peak: 0.6540 MB) Data Comp: Off Server Time: 2026-06-17 06:23:12 UTC
