Page 1 of 3 1 2 3
A few SAS Pictures... #687938 01/20/06 04:17 PM
Elbow_Greese Offline OP
Just enough to wet the appetite anyway, lol!
I'll take more after I get my new tires and wheels on.
The ones on there now are all "spare" quality.
They're 33x9.5 BFG AT's, all fairly well worn, but do a some tread left.
There's a few more on my web page
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: A few SAS Pictures... [Re: Elbow_Greese] #687939 01/20/06 04:20 PM
Adam F Offline
Cool, you SAS's the woody! Looks good man!
What tranny/trans did you use?
97 4R, stock, daily driver
Re: A few SAS Pictures... [Re: Adam F] #687940 01/20/06 04:28 PM
It's a G52 tranny/case setup
If I do a dual case (OK, probably make that a when! lol!), I may swap that for a W56, unless the forward shift is easily adapted to the dual. But that's a ways off for now.
I still have yet to get the "virgin" run in on it!
<img src="/forums/images/graemlins/ignore.gif" alt="" />
94 2wd v6 extracab
Re: A few SAS Pictures... [Re: Elbow_Greese] #687941 01/20/06 04:38 PM
Red_Chili Offline
Toyota Section Staffer
Before you do, better brace those spring hangers or you'll get to do them over - or worse.
Weld some material tying the body mount above the hanger to the hanger top and you should be good.
...unless the forward shift is easily adapted to the dual
The front case can be either top shift or forward shift, it does not matter. In fact, if your existing case is forward shift and you use it for the front reduction box, frankly it's easier to keep it fwd shift.
-Bill
Re: A few SAS Pictures... [Re: Red_Chili] #687942 01/20/06 04:49 PM
Thanks Bill!
I'll get that done next time I'm up there.
For what I do with it now, it'll be fine (mostly on-road driving), but I'll make sure it's done before any off-highway driving.
Better to be safe than sorry, especially in the case of something holding your rig up!
94 2wd v6 extracab
Re: A few SAS Pictures... [Re: Elbow_Greese] #687943 01/20/06 04:56 PM
Red_Chili Offline
You bet. Looks like a good job. Interesting use of Chebie parts.
-Bill
Re: A few SAS Pictures... [Re: Red_Chili] #687944 01/20/06 04:58 PM
bkg Offline
Looks like your ubolt plates are already bending? Or is that just an illusion from the camera?
Brian K. Gallus
Re: A few SAS Pictures... [Re: bkg] #687945 01/20/06 05:01 PM
Red_Chili Offline
Ol' Eagle-eye Gallus spotted a definite problem. They need to have used 1/2" plate, not 1/4". Those will DEFINITELY bend with even light use, unless you don't tighten your U-bolts to spec, which would NOT be recommended esp. in the front. <img src="/forums/images/graemlins/scared.gif" alt="" />
Ax me how I learnt this one... They should warranty both the spring hanger braces and the U-bolt plates IMHO. I would if it were me at least. I see the U-bolt itself is bent (outboard passenger). Those U-bolts should be 5/8s as well IMHO, though if they are at least 9/16s they would probably work with a better plate.
-Bill
Re: A few SAS Pictures... [Re: Red_Chili] #687946 01/20/06 06:59 PM
My intention is to do a Zuk dual coil in the rear, which will take care of that axle, and I also intend to replace the front one as soon as I figure out why I get a bit of "death wobble" when I hit a manhole cover with one side.
I'm sure it's a shim adjustment, just a matter of how much.
But to put everyone at ease, I've only driven this once since I got it back. I won't drive it much until I get those things mentioned fixed.
Thanks for the notes!
Todd
94 2wd v6 extracab
Re: A few SAS Pictures... [Re: Elbow_Greese] #687947 01/20/06 07:12 PM
Esquire812 Offline
And to think....you've only been talking about doing the upgrade from 2wd to 4wd for what.....3 years? Im proud of ya for following through Woody! Looks good, and the advise you are getting couldnt be coming from better sources (Mr.Bill and Brian).
After you do up your dual transfers etc and run out of things to do...we'll turn you into an EFI junkie!
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6433 MB (Peak: 0.7652 MB) Data Comp: Off Server Time: 2026-06-20 02:34:30 UTC
