locker #688318 01/21/06 08:19 PM
toyotaguy55 Offline OP
is there anyway i can get my lockright out of my diff and put it into a newer one? please help me <img src="/forums/images/graemlins/cheers.gif" alt="" />
toyotas look good with body damage
Re: locker [Re: toyotaguy55] #688319 01/21/06 09:18 PM
DirtyHarry Offline
Toyota Moderator
You should be able to swap it over if you follow the installation directions on this page. If the gear ratios are the same you could just swap the whole third also.
Re: locker [Re: DirtyHarry] #688320 01/21/06 09:24 PM
ya but can i do that? i have a newer,less milage 3rd sitting here,and i have the locker in the one in the truck, i want to get the locker out of that 3rd thats in the truck and put it into the newer one,and i dont want to mess with any of the settings in the new 3rd. i nwas just wondering how i can get the old one out. thanks
Re: locker [Re: toyotaguy55] #688321 01/21/06 09:39 PM
ZUK Offline
The key to "keeping the same settings"....in this case, the backlash.....is to mark both carrier bearing spanner adjusters. Even a black "Sharpie" or maybe a scribe works fine for marking. Don't mix up the left and right sides and you can do it. You can doooo it.
mostly stock
Re: locker [Re: toyotaguy55] #688322 01/22/06 12:31 AM
tech30528 Offline
The Lockright is just a replacement for the original spider gears, isn't it? If it's the same as the EZLocker, you don't have to remove the carrier to take it out. Just remove the differential pin, and take the pieces out. No setup required.
Re: locker [Re: tech30528] #688323 01/22/06 07:55 AM
how do i know how much to turn the side thing? is it always flush with the housing? i think this is my new question.i know to line up the marks but does it sit flush with the case no matter what? im lost. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: locker [Re: toyotaguy55] #688324 01/22/06 04:38 PM
ZUK Offline
http://gearinstalls.com/aussielocker.htm
look at this link and some of the other related links on my site. When re-installing the new case into the carrier( http://gearinstalls.com/bearing.htm see bottom of page for pictorial)
....basically, make sure to slam the case right up against the ring gear such that there is no "wiggle play" or backlash......when you screw the 'ring gear side adjuster' in by finger it will line up.....done with that side.
I'd say send it to me but it's too costly to do that.
All the guys on this board are very willing to help you get thru that learning curve......just be ready to help us out by posting clear close up pics <img src="/forums/images/graemlins/kewl.gif" alt="" /> ZUK
mostly stock
Re: locker [Re: toyotaguy55] #688325 01/22/06 04:48 PM
tech30528 Offline
No, they aren't always flush. I have some white touch up paint I use to mark things like this, a paint marker is handy, too. Just paint a line across any point where the ring meets the carrier, then remove the lock tab and count the number on turns it takes the remove the cap. paint that number on the ring with an R of L so you don't get then mixed up. Before you remove the caps, mark where they meet the housing with paint also. The caps are threaded on the inside, and there is enough play in the cap bolt holes to not quite line up the threads, making reassembly difficult.
But if you are replacing bearings or gears, you will have to set it up anyway. So if you are just transfering the locking components, don't take it apart. No need to cause yourself problems.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6232 MB (Peak: 0.7229 MB) Data Comp: Off Server Time: 2026-07-17 04:57:51 UTC
