Squirly
#688689
01/23/06 02:53 AM
I just got an 04 4x4 trd extra cab. I used to drive a full size truck. I've noticed that the tacoma tends to wander on the road. I have to pay attention and really drive it. Is this normal?
Re: Squirly
#688690
01/23/06 05:19 AM
This is not normal, have the front end parts inspected for wear and then have it aligned.
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Squirly
#688691
01/26/06 06:44 PM
Also, what brand of tires do you have? If you have the stock BFG Rugged Trails, then you may need new tires to solve the problem as those are notorious for wander on the highway.
Other than the tires, it is not normal for Taco's to wander.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K 93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: Squirly
[Re: hupptoy]
#688692
01/27/06 01:59 PM
hupptoy My 04 has the BFG Rugged Trail tires and it doesnt wander but the slightest movement of the steering wheel causes it to head for the oppisite lane so you definitely have to pay attention. Makes it tough to change cd's while driving. <img src="/forums/images/graemlins/lol.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver) '90 x-cab 22RE stock '82 Hilux 6" lift (ACES HI) '82 2-Hiluxs' Rally Edition (parts) '81 Hilux 3" lift (parts/restore)
Re: Squirly
#688693
02/03/06 05:28 AM
I just got an 04 4x4 trd extra cab. I used to drive a full size truck. I've noticed that the tacoma tends to wander on the road. I have to pay attention and really drive it. Is this normal? Yes check front end componets and align...you could also be noticing the extremely tight steering...the slightest movement initiates a turn whic is a bit different than most full size trucks.
Re: Squirly
#688694
02/03/06 05:38 AM
There is a ball joint and steering relay rod recall in effect right now; they are in our Toyota Tech Archive section.
Also consider the idler arm bushings being worn out as well. You can fix that yourself; parts under $30 from the dealership.
Re: Squirly
#688695
02/03/06 06:05 AM
Could it be that your fullsize truck had an actual steering gear box, and the Taco is equipped with rack and pinion steering more like a car in it's response on the road ??
Marc
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD.... '90 4Runner 4X4 SR5 5-Spd '86 Shortbed 4X4 5-Spd, SAS'd ASAP '82 Supra 5-Spd Take your automatic and "Stick" it........ My Web Album in Progress
Re: Squirly
[Re: Marc M]
#688696
02/03/06 02:20 PM
In addition to what's been mentioned above, old tires and/or alignment can make it wander. I noticed a large difference when I swapped to new tires and had it aligned.
Re: Squirly
#688697
02/03/06 02:30 PM
I just got an 04 4x4 trd extra cab. I used to drive a full size truck. I've noticed that the tacoma tends to wander on the road. I have to pay attention and really drive it. Is this normal? Yes check front end componets and align...you could also be noticing the extremely tight steering...the slightest movement initiates a turn whic is a bit different than most full size trucks. Is there any adjustment to loosen up the steering a bit? The tight steering is really annoying and quite unlike my previous Toys. Time to start looking for a rust free low mileage pre '95. <img src="/forums/images/graemlins/lol.gif" alt="" />
Thanks
[Re: ACES_HI]
#688698
02/03/06 04:58 PM
Thanks for the info. It appears my truck satisfies all the variables everyone has put forth. The truck has 28,000 miles on it so the tires are getting close to replacement. I'll probably follow all the suggestions when I replace the tires next spring. Thanks again.
