4runner #689396 01/25/06 01:39 AM
I am new to this forum and I am buying a 2002 4-runner to go wheeling in. What are some cheap mods to get it trail ready? I'm not afraid to trim the fenders to fit a larger tire. What is the largest tire I can fit that way. Also, I heard there is an easy way to lift it 3" with the torsion bars?
I have a 72' Bronco that is slowly turning into a show truck, and I'm getting the 4-runner to scratch my off-road itch. Thanks for the help, Craig
Re: 4runner #689397 01/25/06 03:42 AM
Adam F Offline
Welcome to the forum.
The best mod by far is a locking rear differential. There are many options to choose from, from fulltime locking diff to a selectable manual locker.
FYI a 02 4Runner does not have torsion bars. You have a coilover shock/spring instead. You will want to keep the lift under about 2.5", otherwise you will max out your ball joints. I'd suggest a differential drop at the same time you do the lift to relieve your CV boots to make them last longer. I'd go with a cornfed spacer lift if you want cheap and easy. Otherwise, go with some OME (Old Man Emu, from ARB) springs and shocks.
97 4R, stock, daily driver
Re: 4runner [Re: Adam F] #689398 01/25/06 04:28 AM
Do you have any info on the cornfed spacers lift? I just want to go cheap... What about the tire size also. Thanks for your help. Craig
Re: 4runner #689399 01/25/06 03:57 PM
themainjam Offline
There is some very good information about different lift options here: http://www.4x4wire.com/toyota/4Runner/tech/suspension/
a review about the spacers found here: http://www.4x4wire.com/toyota/4Runner/tech/suspension/phil.htm
"On-road this setup is pretty good but it has stiffened up the truck a bit too much. You do feel the bumps. Off-road the added height helps along with the 33" tires. Articulation is very limited. Stiffness and lack of articulation is due to the spacer/spring combo, too much preload of the progressive rate springs."
He fit 285/75/R16 with the 1.5" spacers. it is definitely the cheapest way to go.
Re: 4runner [Re: themainjam] #689400 01/25/06 08:49 PM
Adam F Offline
Phil had the spacers combined with the progressive springs, which is a no no. This combo will significantly stiffen the ride.
If you put spacers on STOCK springs, you will retain the factory ride.
The cornfed website is here http://www.cornfedsuspension.com/
285/75/16 is the ideal tire.
Re: 4runner [Re: Adam F] #689401 01/26/06 12:41 AM
Thanks for the help, I'll look into the lift. I appreciate the suggestions. Also what are some other good 4runner forums on the web. Thanks, Craig
Re: 4runner #689402 01/26/06 12:56 AM
Adam F Offline
PHP: 7.4.33 Page Time: 4.552s Queries: 15 (0.004s) Memory: 0.6120 MB (Peak: 0.7030 MB) Data Comp: Off Server Time: 2026-06-17 15:16:55 UTC
