Bushings #689686 01/26/06 12:01 AM
DentedTacoma Offline OP
I am looking to get a 2" body lift and am wondering if I should be replacing my bushings at the same time. How long should they last, I have a 98 and dont know if they have ever been changed. Also, any suggestions for a quality body lift brand or expected cost would be appreciated (I have found a lot for around $140.00).
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: Bushings [Re: DentedTacoma] #689687 01/30/06 04:01 AM
Has anyone heard anything bad about Performance Accesories body lift kits? Are there any real hidden problems in getting a body lift, I know about the shifter, bumper gaps, gas tank line etc... Anyone out there with a body lift? I just want to get some personal experience and unbiased opinions before I go ahead and purchase one. Thanks.
Maine Rules!
Re: Bushings [Re: DentedTacoma] #689688 01/30/06 05:09 AM
Mark in AZ Offline
Toyota Moderator
My friend calls them 'The devil', but who can blame him seeing he had to pay someone to weld plates where the pucks tore the mounts out of his cab! <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Exploring in a T4R Ltd V8
Re: Bushings [Re: Mark in AZ] #689689 01/30/06 05:14 AM
Mark in AZ Offline
Toyota Moderator
If you must have it....
check out Roger Brown's website for one of the 'better' kits.
Re: Bushings [Re: Mark in AZ] #689690 02/04/06 06:40 AM
Do I have to worry abou the radiator and such. Isn't it mopunted to the body and not the frame? Any worries with that?
Maine Rules!
Re: Bushings [Re: DentedTacoma] #689691 02/04/06 06:58 AM
shanef Offline
i have a 2 inch body lift in my 03 and have not had any probloms. the performance acseceries is a good kit and comes with all necesary bracket for relocations. i also had a 2 inch in my 92 witch was wheeled very hard and never had a problom
03 extra cab 3 inch suspinsion lift 2 inch body lift 35 bfg mt's and some other stuff
Re: Bushings [Re: DentedTacoma] #689692 02/04/06 07:13 AM
kewlynx Offline
2 of my old jalopies have 2" lifts on them. If you go getting in to 3" or more, then you have to start tweaking things.
You'll like it; gives you more room in the tight spots to work on stuff.
**ubi apis- ibi salus**
Re: Bushings [Re: kewlynx] #689693 02/05/06 06:47 PM
Did you guys have to do any cutting so the shifter would be abe to go into gear correctly? A lot of people say you cant go into 4hi if you dont do some adjustive cutting in the floor.
Maine Rules!
Re: Bushings [Re: DentedTacoma] #689694 02/06/06 03:34 AM
shanef Offline
did not have to cut any thing shifts just fine
Re: Bushings [Re: shanef] #689695 02/06/06 05:50 AM
Did you install the kit by yourself (or with the help or friends). I want to do it on my own so I dont have to pay a shop to take their time on it. What might I need? A couple jacks or strong guys? I can be patient if it takes awhile but I dont want to mess anything up, it sounds pretty straight forward though.
Maine Rules!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6354 MB (Peak: 0.7426 MB) Data Comp: Off Server Time: 2026-06-02 03:52:45 UTC
