early 22r distributor... #689766 01/26/06 02:29 AM
84toyota Offline OP
I've rebuilt an early 22r motor... I think it is an '81 or '82 motor - It had the dual timing chain, as well as the main bearings which match the 81-82 years... So kind of a stupid question, but because of the dual timing chain, does that require a distributor from those specific years? The engine I rebuilt did not come with a distributor, and I'm having trouble tracking down a distributor from an '81 or '82 truck... Will any of the celica distributors swap with the truck? Did the celicas have dual row timing chains from the early 80's? Better yet - does anyone have a spare distributor (dual row t-chain) that they're looking to find a home for?
Thanks,
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: early 22r distributor... [Re: 84toyota] #689767 01/26/06 02:45 AM
kyle-22r Offline
distrutor is really irrelevant. the difference is in the distributor drive on the camshaft, it's different over the years with different variations of the engine(20R with electric fuel pump had a gear that was longer that didn't use a washer or fuel pump cam lake later engines), i think dual chain/single chain might be different.
however, any distributor from a 20R/22R/22R-E, any year will work fine. just make sure it's got the correct type of plug(round vs square) for the ignitor, or splice yours on.
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5850 MB (Peak: 0.6332 MB) Data Comp: Off Server Time: 2026-06-18 14:36:35 UTC
