Page 3 of 3 1 2 3
Re: power steering pressure feed line leak [Re: TomPoh] #691432 01/11/08 08:25 PM
TomPoh Offline OP
i'v been warned by edelmann that welding on an adaptor may not be a good idea. ~2000psi for power steering. <img src="/forums/images/graemlins/frown.gif" alt="" />
95 T100 SR5 Xcab 4X4
Re: power steering pressure feed line leak [Re: TomPoh] #691433 01/11/08 08:41 PM
BamZipPow Offline
Will lines from a 1993 T work? There's one here fully intact. Not sure what's left though... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: power steering pressure feed line leak [Re: TomPoh] #691434 01/11/08 10:13 PM
ErikB Offline
Toyota Moderator
Brazing would probably be a better option. Stronger than welding and doesn't affect the base metal.
http://home.4x4wire.com/erik
Re: power steering pressure feed line leak [Re: TomPoh] #691435 01/15/08 07:58 PM
garym Offline
You might check with this guy:
95 T100 Parts
He is selling off just about everything on eBay from a 95T
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: power steering pressure feed line leak [Re: garym] #691436 01/16/08 01:19 PM
TomPoh Offline OP
thanks...still dealing with this line.
i'm gonna take it out, and stop by a hydraulic line shop. out of 10 local shops, this is the only one that claims to be able to handle the 10mm hardlines.
tom
Re: power steering pressure feed line leak [Re: TomPoh] #691437 01/21/08 08:47 PM
BamZipPow Offline
A local 1996 T-100 is available fer parts...
Re: power steering pressure feed line leak [Re: ErikB] #691438 02/01/08 01:24 AM
TomPoh Offline OP
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> well after about a month of searching, i found a shop that made me a hose by brazing connectors on the hardlines at both ends. so i'm reusing the oem connectors at the ends. they then made the rubber line to give the needed length. i'll see how the install goes this weekend...don't expect any problems.
the standard hydraulic hose places (typically industrial) couldn't deal with metric, nor many auto applications.
the shop that finally was able to braze on the universal connectors (JIC) sort of specializes in radiators...so perhaps brazing is one of their skill sets.
tom
Re: power steering pressure feed line leak [Re: TomPoh] #691439 02/01/08 04:37 AM
kewlynx Offline
Thanks for posting your fix. Wish more folks would. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6306 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-06-21 00:12:37 UTC
