Re: power steering pressure feed line leak
[Re: TomPoh]
#691432
01/11/08 08:25 PM
i'v been warned by edelmann that welding on an adaptor may not be a good idea. ~2000psi for power steering. <img src="/forums/images/graemlins/frown.gif" alt="" />
95 T100 SR5 Xcab 4X4
[Re: TomPoh]
#691433
01/11/08 08:41 PM
Will lines from a 1993 T work? There's one here fully intact. Not sure what's left though... <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: TomPoh]
#691434
01/11/08 10:13 PM
Toyota Moderator
i'v been warned by edelmann that welding on an adaptor may not be a good idea. ~2000psi for power steering. <img src="/forums/images/graemlins/frown.gif" alt="" /> Brazing would probably be a better option. Stronger than welding and doesn't affect the base metal.
[Re: TomPoh]
#691435
01/15/08 07:58 PM
You might check with this guy: 95 T100 Parts He is selling off just about everything on eBay from a 95T
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
[Re: garym]
#691436
01/16/08 01:19 PM
thanks...still dealing with this line.
i'm gonna take it out, and stop by a hydraulic line shop. out of 10 local shops, this is the only one that claims to be able to handle the 10mm hardlines.
tom
[Re: TomPoh]
#691437
01/21/08 08:47 PM
A local 1996 T-100 is available fer parts...
[Re: ErikB]
#691438
02/01/08 01:24 AM
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> well after about a month of searching, i found a shop that made me a hose by brazing connectors on the hardlines at both ends. so i'm reusing the oem connectors at the ends. they then made the rubber line to give the needed length. i'll see how the install goes this weekend...don't expect any problems.
the standard hydraulic hose places (typically industrial) couldn't deal with metric, nor many auto applications.
the shop that finally was able to braze on the universal connectors (JIC) sort of specializes in radiators...so perhaps brazing is one of their skill sets.
tom
[Re: TomPoh]
#691439
02/01/08 04:37 AM
Thanks for posting your fix. Wish more folks would. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6282 MB (Peak: 0.7273 MB) Data Comp: Off Server Time: 2026-06-20 10:32:07 UTCValid HTML 5 and Valid CSS
