Putting an '94 22re into a 185 4runner #692004 02/01/06 02:38 AM
JaredT Offline OP
the 22re in my 1985 4runner is tired. I bought a 1988 4x4 pickup with a 1994 22re in it. I want to put this engine in my 4runner. Is there something different on the wiring or fuel injection between 1985-1987 and 1988-1994 because I have been seeing there are computer chips on ebay for the 1988-1994 22re. but not the earlier ones. I would like to put this later engine in my 4runner and still be able to put one of the chips on it. I am trying to see what will have to be done to put this engine in the 1985 4runner. Thanks
Re: Putting an '94 22re into a 185 4runner [Re: JaredT] #692005 02/01/06 03:56 AM
matts Offline
There were variations in the engine computers and the ignitors over the years. I think they changed almost every year from '85 to '88 and then (verify this first) '89 - '92 were the same, then '93 - '95 were the same.
If you want to run that '94 motor in your '85 you'll probably need an engine wiring harness, a chassis wiring harness and the correct ECU (engine computer). You'll basically have to rewire your whole truck or do a lot of splicing of your old chassis harness. The '94 has different O2 sensor wiring and needs a VSS signal from the transmission (if I remember correctly). -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Putting an '94 22re into a 185 4runner [Re: matts] #692006 02/01/06 04:55 AM
kyle-22r Offline
the easiest way is to ubolt the manifolds from the new engine and swap on your old manifolds/sensors/wiring.
the upper intake plenum on the '94 is more desirable, so you might want to swap that on.
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.5926 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-06-23 16:08:29 UTC
