timing advance #692393 02/01/06 10:34 PM
L
lookmomnobrains Offline OP
im still having some trouble trying to get power from my 84' truck. i thought i was having carb problems but now i think timing could be the culprit. my truck makes full power and falls flat on its face at 4000 almost every time. could my vacum advance not be working properly? i have another dist for this truck.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: timing advance [Re: lookmomnobrains] #692394 02/02/06 03:02 AM
kewlynx Offline
On the carbies, you remove and plug the vacuum advance, then set your timing to 0 dg tdc. When you hook the vacuums back up, you should see it advance to right around 8 dg.
If you have a vacuum tester, you can hook up right off the distributor with the cap off and observe the motion if working.
Consider also the signal generator; those give up, tho' once in a great while.
EGR and plate aren't all carboned up, or have you looked yet?
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5879 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-06-07 13:00:41 UTC
