Crapola MPG #692482 02/02/06 04:03 AM
ChokeUoutcold Offline OP
I have a 93 22re reg cab 5 spd with 32's. Prob is lately Im getting horrible gas milage. (14mpg highway) I just changed oil and filters, checked tire pressure. Any ideas?
89 YJ, 258cid, ax-15, Webber carb, HEI, 33x12.5's, nerfs, custom diamond plate
(for sale)
93 Yote P/U, 22RE, trim'd front, exaust, 32"BFG's
(for sale)
Re: Crapola MPG [Re: ChokeUoutcold] #692483 02/02/06 04:45 AM
OOP'S Offline
What gears do you have in the diffs? Is that corrected or un-corrected mileage? Does it have a lift on it. How wide are the tires
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Crapola MPG [Re: OOP'S] #692484 02/02/06 04:59 AM
Gotta check on gears, 14 mpg is what I'm getting now-was getting 20 on highway, minor lift-s/o in back some trimin' up front, 12.50 tires
(for sale)
(for sale)
Re: Crapola MPG [Re: ChokeUoutcold] #692485 02/02/06 02:01 PM
ACES_HI Offline
It could be a bad O2 sensor. They dont always trigger the CEL when they go bad. Either check for codes diagnostics or physically test the sensor as shown here... O2 sensor
There is also a general drop of mpg's in the winter due to oxygenated gas but not to the extent of 14mpg. Fresh plugs/wires/cap/rotor and timing might also help.
P.S. Hello from up the river and welcome to the forum. <img src="/forums/images/graemlins/cheers.gif" alt="" /> I actually live north of Hudson. Send me a pm if ya like.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Crapola MPG [Re: ChokeUoutcold] #692486 02/02/06 02:26 PM
bkg Offline
What changed between the time you were getting 20 and 14? And what's an "s/o"?
Brian K. Gallus
Re: Crapola MPG [Re: ChokeUoutcold] #692487 02/02/06 03:53 PM
jcssurf Offline
Well considering your tire size jumped by almost 14% and I'm guessing you didn't fix the speedo, your mileage is more like 16.
I'm going to agree with the 02 sensor, since it was such a sudden drop. It may need a tune up too. You should still be able to get almost 20 out of that truck though. Regearing would help too.
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: Crapola MPG [Re: jcssurf] #692488 02/03/06 12:53 AM
S/O = Spring Over, I haven't changed anything on the truck except my sirius antenna, How do I tell what gears I have??
(for sale)
(for sale)
Re: Crapola MPG [Re: ChokeUoutcold] #692489 02/03/06 02:10 AM
Elbow_Greese Offline
Just to clarify, this is a 4wd?
You mentioned the S/O, which is stick on the 4wd. If you did this on a 2wd, then your actual mileage would be much better.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: Crapola MPG [Re: ChokeUoutcold] #692490 02/03/06 04:02 AM
TimsToyo Offline
What about a stuck EGR valve. I just went through something very similar. Pulled the EGR and everything appeared to function. I couldn't find a gasket in stock so I made my own along with a couple of block off plates. I can't believe how much better it runs now. The EGR was definitely malfunctioning on mine. Just a thought...
'86 Toyo 4wd
'04 600RR
Re: Crapola MPG [Re: ChokeUoutcold] #692491 02/03/06 05:34 AM
kewlynx Offline
Gears http://www.4x4wire.com/toyota/faq/parts/
Axle codes on your data plate; www.4Crawler.com
Assuming you're still stock under there.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6311 MB (Peak: 0.7391 MB) Data Comp: Off Server Time: 2026-06-23 15:35:08 UTC
