cannot get the intake of my 88 2.6 trooper! #692571 02/02/06 03:39 PM
1
1sttrooperII Offline OP
what's the trick? all the bolts appear to be out, the man. was put on with blue sealant but this is ridiculous. It wont budge. HELP PLEASE!!!!
Re: cannot get the intake of my 88 2.6 trooper! [Re: 1sttrooperII] #692572 02/02/06 04:50 PM
ShowMeDave Offline
There are one or two bolts(or nuts/studs) on the underside that are very hard to see....especially when it's all together. Get a mirror or something and check under there to make sure you didn't miss one. The studs sort of hold it in place so it might take a little force to pop it loose. Just don't get too carried away and break something.
That front stud is a PITA also. First time I took mine apart I had to just use a pair of vicegrips on the stud to get it out....totally ruined it. I replaced the stud with a long bolt so I would never have to deal with that stupid thing again.
David
?'90 Trooper?2.6L?Auto?DELTA Cam?AMC Head?"DN" Lift?SlakAzz Sliderzz
?TrXus M/T's?Black Rockcrawlers?Lockers by MIG & ARB?ProComp ES9000's
?Pics and junk...Thx Tad!!
Re: cannot get the intake of my 88 2.6 trooper! [Re: ShowMeDave] #692573 02/02/06 05:00 PM
Bigpoppax2 Offline
Ditto the intake being a PITA to get off. I pulled the head on mine and left the intake intact. I swapped it out on the bench.
There are bolts on the under side of the intake that I really can't see getting to very easily. Maybe from underneath the truck reaching up through where the carbon cylinder is.
Why does the intake need to come off? If it's for a head change just pull the head with it on there.
Joe
Re: cannot get the intake of my 88 2.6 trooper! [Re: Bigpoppax2] #692574 02/02/06 05:06 PM
1
there are some hoses under it that need replacing, and the son of a gun that I bought it from did not use gaskets, only blue sealer. Head gasket tested fine, we are in luck there. Thanks for the help, BTW, there are only 8 bolts/nuts total holding it on right?
Re: cannot get the intake of my 88 2.6 trooper! [Re: 1sttrooperII] #692575 02/02/06 06:20 PM
ShowMeDave Offline
http://www.4x4wire.com/4x4/isuzu/tech/cyl_head/P1010039.JPG
http://www.4x4wire.com/isuzu/tech/cyl_head/head.htm
Looks like 8 but not sure if 1 or 2 of the other holes on the front of the head are for the intake also. Been a long time since I took mine apart. Those should be easy to see if they are. Have fun.
David
Re: cannot get the intake of my 88 2.6 trooper! [Re: ShowMeDave] #692576 02/02/06 07:12 PM
Richard Saylor Offline
99% sure it's only 8.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6100 MB (Peak: 0.6811 MB) Data Comp: Off Server Time: 2026-05-25 16:22:04 UTC
