Changing OE bulbs with led bulbs #693667 02/06/06 06:08 AM
Chris_Tacoma Offline OP
Hello all,
Has anyone changed any of their bulbs to led bulbs ? I like the looks of these bulbs but not sure how they would look as far as brake lights and turn signals go. I went to a site that recommended using the same color led as the lens. Here is the site http://www.superbrightleds.com/carbulb-notes.htm
I thought using a clear led would be better than red on red <img src="/forums/images/graemlins/confused.gif" alt="" /> ?? Anyone have any info on this or pictures ? Tia
Chris
05 Tacoma Extra Cab
The Reaper Is My Copilot
Re: Changing OE bulbs with led bulbs [Re: Chris_Tacoma] #693668 02/06/06 02:16 PM
Dandeman Offline
Toyota Moderator
I tried changing the rear running and brake lights to red LED..
I installed the LED bulb on one side only so I could compare brightness. The running lights were about the same brightness, but the brake lights were definitely dimmer..
So I took it out..no way am I going to run with dimmer brake lights..
The Toyota tail light reflector design makes good use of the light given off to the side of a standard bulb, but the LED bulb (even one with additional LEDS mounted in a circle pointing to the sides) doesn't work well with the reflector.
Re: Changing OE bulbs with led bulbs [Re: Dandeman] #693669 02/07/06 01:47 PM
I installed some LED bulbs that supposedly works better and technically they do in regards to heat/longevity/etc, but I opted to go to colored bulbs from Japan (bluebirds). I have the LED bulbs if your interested in trying them out. They're just sitting in my glove box!! lol
Re: Changing OE bulbs with led bulbs #693670 02/08/06 08:28 PM
so far i am not convinced that the led is better so i just might leave what i have in already. Thanks for all the input.
05 Tacoma Extra Cab
Re: Changing OE bulbs with led bulbs [Re: Chris_Tacoma] #693671 02/15/06 05:20 PM
Chris,
If you really want OEM or better brightness from a set of LEDs, it's gonna cost you. I tried the Ebay ones for awhile but wasn't impressed due to the lack of side lighting from the bulbs and the fact you should install a load resistor to compensate for the lack of voltage drop of the LED fixture. There is one company that makes a commercial quality bulb with side LEDs but they are spendy. Check em out... LEDtronics <img src="/forums/images/graemlins/kewl.gif" alt="" />
One thing to note on the resistors...they get extremely HOT during operation so consider that during placement.
Re: Changing OE bulbs with led bulbs #693672 02/15/06 08:28 PM
Thanks FLYMHI for the info, I'll check out that site. <img src="/forums/images/graemlins/patriot.gif" alt="" />
05 Tacoma Extra Cab
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6084 MB (Peak: 0.6749 MB) Data Comp: Off Server Time: 2026-07-15 02:52:24 UTC
