What are the sign of a headgasket going out? #693680 02/06/06 09:27 AM
I
irsean Offline OP
I have begun to smell the faint smell of paper burning and a little coolant leaks out near the firewall. I thought it might be the heater hoses going out but I can't figure out what the paper smell is. Is this V-6 about to blow a gasket?
1993 4Runner SR-5 4WD V-6 Auto Trans
1990 Pick-up (Hilux) 2WD SR-5 V-6 Auto Trans
Re: What are the sign of a headgasket going out? [Re: irsean] #693681 02/06/06 05:26 PM
engnbldr Offline
>>>*The leak can usually be isolated by using a radiator pressure tester to bring the system up to 15# or so, then simply watch for where the leak appears.
*The "paper burning" comment interests me, I noticed a similar smell from my old Camaro. I even looked around under the hood for insulation or something like that, finally I figured out the old engine (200,000+ miles is very old for a GM engine) was using a small amount of oil, the smell was actually coming from the exhaust.
Just a combination of oxygenated fuel with oil residue and the Cat dealing with it, I believe. If some coolant is reaching the combustion chamber, then this will increase oil usage some. That might be what is going on.....*EB
*Beats the he** outa me!....*LOL**...
Re: What are the sign of a headgasket going out? [Re: engnbldr] #693682 02/10/06 01:12 AM
I
irsean Offline OP
Any idea on where to get a coolant pressure tester? I can't seem to find one for sale or rent.
Re: What are the sign of a headgasket going out? [Re: irsean] #693683 02/10/06 01:35 AM
mosk Offline
This is what you want:
http://www.amazon.com/gp/product/B0002SRGWU/002-0328033-7158410?v=glance&n=228013
I have one and it really helped me with my cooling system probmels a few years ago.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: What are the sign of a headgasket going out? [Re: mosk] #693684 02/10/06 01:37 AM
I
irsean Offline OP
That looks like the exact one Autozone rented me that didn't fit.
Re: What are the sign of a headgasket going out? [Re: irsean] #693685 02/10/06 03:17 AM
mosk Offline
You may need an adapter like this one:
http://www.atoolcrib.com/catalog/product_info.php?products_id=707&language=1
I don't know if this is the only Toyota adapter. FWIW, I didn't need an adapter to use the Stant tester on my 1986 truck.
Jeff Moskovitz
Jeff's 22R-TE page
Re: What are the sign of a headgasket going out? [Re: mosk] #693686 02/10/06 05:49 PM
I
irsean Offline OP
Nevermind. It was the stant MT-300. It doesn't matter anyway. I found the leak. It was (as I suspected) a heater hose. I couldn't see a leak so I starting pulling on all the hoses until I found one that gave way. Replaced it and eveything is good now. Thanks everyone.
PHP: 7.4.33 Page Time: 0.685s Queries: 15 (0.003s) Memory: 0.6186 MB (Peak: 0.7097 MB) Data Comp: Off Server Time: 2026-05-29 23:30:23 UTC
