SAS Axle Option #694094 02/07/06 09:45 PM
jmcentire Offline OP
I have found a dana 44 front axle with a new set of warn hubs off a 76' Chevy for $150. Will this axle work for an SAS on a 96 rodeo without too much mod? Also how is the price? I plan on doing a SAS within a year or two so is it a good enough deal to buy now and store it until i do the SAS?
95.5 Rodeo 4x4 V6
3" DOR Lift
33x12.5x15 BFG A/Ts
Re: SAS Axle Option [Re: jmcentire] #694095 02/07/06 10:26 PM
RobG Offline
its a good axle (has flat top knuckles) for a good price ($150-200 is going rate in my area)... your biggest issue is its going to be the width... Chevy axle is a full width, 67-69"... as opposed to the commonly used Waggoneer D44 which is more like 62"
-Rob
Re: SAS Axle Option [Re: jmcentire] #694096 02/08/06 04:49 AM
maxwell417 Offline
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: SAS Axle Option [Re: jmcentire] #694097 02/08/06 04:37 PM
sweater Offline
This is a good deal, I think. The only thing that you might want to do is to swap out the knuckles for flat-topped ones (I milled my passenger's side for the steering arm). I believe I used the knuckles off of a Scout or something - $90 for the pair, pulled for me at a local junk yard. You'll also want to go full-width in the rear, which usually means the matching 12-bolt from that application or a 14-bolt from something else.
Thanks for the shout-out, Curt... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Once you go full width you never go back.
<img src="/forums/images/graemlins/smile.gif" alt="" />
- mike
Re: SAS Axle Option [Re: sweater] #694098 02/08/06 05:43 PM
RobG Offline
All chevy's use a flat top already milled and drilled on the drivers side due to Chevy's steering arm design. the 74-76 years also used flat tops on the passenger side too.
This is the year you want if you want flat top knuckles to run a hi or crossover type steering.
-Rob
Re: SAS Axle Option [Re: RobG] #694099 02/08/06 05:44 PM
sweater Offline
Didn't know that - I originally got the center section (everything minus the knuckles) for free and had to purchase the knuckles seperately.
Go figure.
- mike
PHP: 7.4.33 Page Time: 0.054s Queries: 15 (0.007s) Memory: 0.6110 MB (Peak: 0.6832 MB) Data Comp: Off Server Time: 2026-11-17 13:51:04 UTC
