speedo dial making noise and shaking #694435 02/08/06 07:06 PM
only when it's cold outside does the speedo dial (or cable?) make a grinding or shaking noise (kind of like in a bind or something) the dial shakes and vibrates
once the engine warms up it's not so bad, and when it's warm outside, it does't happen at all
and theories???
thanx <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: speedo dial making noise and shaking #694436 02/08/06 07:24 PM
4Crawler Offline
Cable lube drying up is one possibility.
Re: speedo dial making noise and shaking [Re: 4Crawler] #694437 02/08/06 10:55 PM
Red_Chili Offline
Toyota Section Staffer
I once had the identical symptoms in my 2nd gen 4Runner. Roger (as usual) is spot-on.
-Bill
Re: speedo dial making noise and shaking [Re: Red_Chili] #694438 02/09/06 04:40 AM
A
allochris Offline
mine's been doing it forever. I've sprayed in some wd40 throught the insert of the speedo gauge end, it's still making noise. Understandably, it doesn't get higher than -10?C here. Yes it's annoying, so just crank up the music!!! If it ain't broke, don't fix it.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: speedo dial making noise and shaking [Re: Red_Chili] #694439 02/09/06 04:51 AM
TheToeCutter Offline
I thought I had a similiar problem with my '94 4X4, but when I pulled apart the dash and pulled out the instrument cluster I was suprised to see no speedo cable connected to speedometer. Maybe its because its a 1994, but there was no speedo cable must be electronic sensor I guess.
My speedo needle didn't shake, but I can hear a ticking noise when driving and its not the engine (ticking doesn't follow RPM's of engine)
I am missing somehting ?
Re: speedo dial making noise and shaking [Re: TheToeCutter] #694440 02/09/06 05:17 AM
A
allochris Offline
does the sound/ticking follow with the spd of your car rolling in neutral let's say? Mine does.
Re: speedo dial making noise and shaking [Re: allochris] #694441 02/09/06 04:55 PM
Yes allochris my noise follows the speed of the car (in neutral), not engine RPM's. So its either the speedo cable if I have one, or something in the front driveline.
I guess I'll look on my transmission again and look for a cable, but I don't think my 1994 has one.
Re: speedo dial making noise and shaking [Re: TheToeCutter] #694442 02/09/06 05:53 PM
Ooooohh Dang! Maybe I'm NOT losing my mind. ( 'course,, THAT wouldn't take long , anyway ) Just clicked this link from another post. Scroll down to the last entry -- Type 6-B Transfer case. It appears that the speedo drive is, in fact, electrical and not mechanical. If ya look at the entry just above that, Type 6-A, it lists a mechanical drive cable. Evidently, Toyota switched sometime around 91-92 and started installing electrical senders for the speedo.
http://www.marlincrawler.com/tcaseinfo.html
Mike in AR
Re: speedo dial making noise and shaking #694443 02/09/06 08:39 PM
V
Voyager Offline
and theories???
Funny, just today, on the way to work, I decided I was going to post on this exact problem. <img src="/forums/images/graemlins/lol.gif" alt="" />
Mine sure sounds like a cable flipping around in the housing, it seems odd that it only does it in cold. Is factory lubrication a form of grease that hardens up in the cold? Shouldn't grease still lubricate when cold? What happens to your wheel bearings when the temp is cold?
Another clue, if I warm up the truck, but don't blow the heater (specifically the defroster) in the cab, it still does it. If I heat the cab, it goes away.
It is... a mystery. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: speedo dial making noise and shaking #694444 02/18/06 08:28 PM
So...Has anyone fixed this or is everyone just turning up their stereos? My 90 SR5 PU is doing the same thing and i'd like to fix it. It appears that the instrument cluster needs to come out, which i am not looking forward to (it was -20 yesterday AM). What kind of lube needs to be used? I seem to recall that speedo cables require a dry graphite lube, not a grease or oil.
I looked in the 93 FSM that is linked to this site and I couldn't find anything-I assume that in 93 Toyota used an electronic speed.
If anyone has fixed this successfully I'd sure love to hear aboout it.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6354 MB (Peak: 0.7585 MB) Data Comp: Off Server Time: 2026-06-19 06:44:11 UTC
