22RE Knock Sensor #695480 02/11/06 02:03 PM
86 4runner, Code 12. I have checked the wiring, replaced the ECU with a known good, replaced the sensor itself with a known good, and checked the connectors.
What else can cause a code 12?
Re: 22RE Knock Sensor #695481 02/11/06 02:21 PM
RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
Check Here:
http://www.off-road.com/toyota/tech/codes/index.html
Mike in AR
Re: 22RE Knock Sensor #695482 02/20/06 04:58 AM
RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ......
Uh, no, like I wrote its a 22RE, a code 12 is a knock sensor, not rpm signal.
Yall oughta be able to tell me sompin to diagnose beyond just reading me the manual, I already had that!!!
Re: 22RE Knock Sensor #695483 02/20/06 05:29 AM
willzrunna96 Offline
code 12 is not a knock sensor
a knock sensor would throw codes 52 or 53
id suggest you take off the ingition wire on the starter and clean in also clean all grounds. if that dont help trace wire from the pick up coil in the distributer and check for corrosion
take some time to view the FSM thats done stickied
Re: 22RE Knock Sensor [Re: willzrunna96] #695484 02/20/06 05:51 AM
4Crawler Offline
The earlier engines/ECUs (EFI) have a slightly different and reduced trouble code list than the later (TCCS) ECUs do:
More info:
http://www.4crawler.com/4x4/CheapTricks/index.shtml#TimingCheckConnector
I guess the early engines don't have as many problems as the later ones <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 22RE Knock Sensor [Re: willzrunna96] #695485 02/21/06 03:45 AM
willztoypickup91, you dont know what you are posting about, try looking at your "done stickied", code 12 is the code for a knock sensor on the early trucks. Thanks for trying, but you aint helping.
I have the FSM, it says exactly what Roger posted, no more, no less, no troubleshooting help whatsoever.
Thanks Roger, I'll take a look at your site.......
Re: 22RE Knock Sensor #695486 02/21/06 04:59 AM
you belong on pirate 4x4 just trying to help so take any advice you get <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: 22RE Knock Sensor #695487 02/21/06 06:19 AM
Well there is one possibility that comes to mind after reading your post and the info on code 12 and reviewing an 86 wiring schematic.
Make sure that you have a good ground to the engine block. Since the knock sensor's body completes the signal path to ground (engine block).
Also I assume the knock sensor wire is the same or similar to the later years, where there's an inner conductor and then an outer braided shield wire.
The outer shield is connected on the ECU side "only", which the terminal it's connected to is a sensor ground, so make sure the ECU has a Good ground as well.
The inner conductor goes from the knock sensor terminal to the ECU's KNK input terminal. Double check for continuity while wiggling the wire around to verify that the wire isn't going open (broken wire) with the movement of the engine when it's running.
Otherwise you've covered all bases on the knock system
1)Wiring circuit
2)Knock Sensor
3)The ECU
You replaced all with known working units except the wiring!!!!
The only other possibility would be the igniter, but there's no reference to the igniter being involved in the knock system.
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 22RE Knock Sensor [Re: willzrunna96] #695488 02/21/06 07:16 AM
4WD22R Offline
Here! BTW, they love n00bies that make snide remarks over there!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: 22RE Knock Sensor #695489 02/24/06 09:43 PM
Stomper Offline
My check engine light has come on today. I just pulled the codes and I have a #5 O2 sensor and the #12 Knock sensor. I kinda figured the O2sensor was going. But I had no clue about the knock sensor. Where is the knock sensor BTW I cant find it.
This is the funny part. The check engine light has come on a few times. Mostly going low speeds, The light would come on and I could rev it up and the light would go out. But today the light comes on above 3000rpms and wont go back out till I turn the Runner off. And it dosen't come back on till I hit 3000rpm's again.
BTW mines a 85 4Runner with the 22REC
1985 4runner
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6326 MB (Peak: 0.7586 MB) Data Comp: Off Server Time: 2026-11-16 08:53:03 UTC
