different gauge cluster wiring harnesses for auto and manual??
#695538
02/11/06 08:10 PM
I have a 1985 4runner 22re auto(with normal and power trannie option) completely original. I purchased a sr5 gauge cluster out of a 1985 toy pickup 2wd 22re auto (WITHOUT normal/power trannie option) extended cab shortbed. When I put this cluster in my 4runner I changed the oil pressure sending unit and the cluster goes crazy. It shows a full tank of fuel when it is only 1/2 and the temp goes to the red right away and the tach does not work. I borrowed a 1986 sr5 cluster with the normal power trannie option and that gauge cluster works perfectly and the tach works. So I took the non normal power optioned cluster and put it in a 1988 4wd 5speed pickup and that same cluster that would go crazy in the 4runner works fine in that one. I have come to the conclusion that toys with the auto and normal/power trannie modes have a different wiring somewhere. I am putting a 5 speed into my 4runner and I need to know which wires i need to remove and put into it for the instrument cluster with the full set of gauges to work in it. Thanks
Re: different gauge cluster wiring harnesses for auto and manual??
[Re: JaredT]
#695539
02/11/06 09:40 PM
i believe it is. i put an auto cluster from an 87 in my 84 and the tach didnt work. the cluster from my 87 5spd worked though.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5860 MB (Peak: 0.6344 MB) Data Comp: Off Server Time: 2026-06-24 13:00:29 UTCValid HTML 5 and Valid CSS
