Re: 1995 3.2 SOHC Hydro Lock [Re: vanduker] #695964 02/21/06 04:49 PM
JLEMOND Offline
good luck on the drilling of the rest of the bolt hole, i would not rust the hole repair stuff on a head bolt , it works great on parts that do not have a lot of stress on them , it is a mix of powered metal and high grade epoxy, take alook at their matrix chart and for the size of the head bolt , it doesn,t appear to have enough strength to trust for a long period , not counting the amount of work to repair if it doesn,t hold, if worst comes to worst let me know later i have 12-15 of those blocks on hand most all of the time that could be rebuilt , JERRY
Re: 1995 3.2 SOHC Hydro Lock [Re: JLEMOND] #695965 02/22/06 06:47 AM
V
vanduker Offline OP
Thanks.
Any idea how much the head bolts actually stretch when tightened?
I managed to get it tapped what looks to be deep enough - .18" beyond what will be required to have the bolt tight against the head with a head gasket in between. I should have at least .15" for bolt stretch and I can't imagine even those spindly little bolts stretching .1" with ~ 48 ft/lbs of torque on them.
I could probably tap it a little further down but I'm afraid that every time I run and tighten the tap that I am removing a small part of the threads, even if it is a small amount.
Re: 1995 3.2 SOHC Hydro Lock [Re: vanduker] #695966 02/22/06 08:58 AM
Rodeofox Offline
Well I finally had sucess!!! The broke bolt is out!!!! Wasn't that hard. I drilled in the center of the broke stud, starting with a small bit then working my way up to a size that was big and deep enough for me to get the reverse bit in it. I did have to find a socket that would fit it cause it was to deep to use to the tap. I used a socket instead and once it grabbed it came out nice and easy. The threads are fine as well!!
I can email you a pic of the "tool" i used if you want. Just P.M. me with your email. Sent you a P.M. as well.
Tomorrow I can tell you how much my stock head bolts stretched ((16 new head bolts came in for the tune of $100)
Re: 1995 3.2 SOHC Hydro Lock [Re: vanduker] #695967 02/22/06 04:24 PM
JLEMOND Offline
TO TELL YOU THE TRUTH I HAVE NEVER MEASURE HEAD BOLT STRETCH, BUT BY GOING HOW ROD BOLTS STRETCH, WHICH IS MINIMUL, I WOULD GUESS MAYBE .005 THOU, .150 IS A BUNCH, OF STRETCH EVEN THOUGH THE ARE KINDA LONG , I WILL TAKE A LOOK LATER TODAY AT A NEW BOLT AND A USED ONE AND SEE IF I CAN MEASURE ONE AND GET BACK TO YOU ON THIS ONE , HOWEVER IT WOULD ONLY BE AN APPROXIMATE READING AS YOU KNOW THE BOLT WOULD NOW BE IN A RELAXED STATE , JERRY
Re: 1995 3.2 SOHC Hydro Lock [Re: JLEMOND] #695968 02/27/06 02:44 AM
V
vanduker Offline OP
Got the truck back together. What a project it has been. Hydrolock, bent rod, broken head bolt. Back together but with a water leak which is the o ring in the middle of the valley then try to start only to find that the new timing belt is faulty (a tiny bit too long). Installed a Gates belt and it fired right up and seems as good as, well as good as can be expected for a "free" truck with 200k miles.
Thanks so much to all you guys for the support.
Re: 1995 3.2 SOHC Hydro Lock [Re: vanduker] #695969 02/27/06 03:00 AM
JLEMOND Offline
HEY THAS GREAT, I FINALLY GOT TO MEASURE THE HD BOLTS , I COULD NOT FIND MY MIKE THAT NOT WHERE IT WAS SUPPOSSED TO BE , BUT ANYWAY , I MEASURED A USED BOLT AND A NEW ONE AND THE NEW ONE WAS 7/10 THOUSANDS SHORTER THAN THE USED ONE , HAVE NO IDEA HOW LONG THE USED ONE HAD BEEN USED , I JUST TOOK IT OUT OF A CYL HEAD AND MEASURED IT , EVIDENTLY NOT A LOT OF STREATCH . JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6165 MB (Peak: 0.6871 MB) Data Comp: Off Server Time: 2026-06-22 06:10:41 UTC
