Page 2 of 3 1 2 3
Re: frustrated with rebuild process... [Re: engnbldr] #696535 02/27/06 04:40 AM
84toyota Offline OP
Can you explain where the plug is that is down by the pan rail? Is this on the back of the engine? The engine has a fairly good drip, and with the truck parked at an angle (front jacked up higher than rear), the oil drips becomes quite a bit worse... it's not like I have quarts pouring out, but I do have a pretty good puddle going... Thanks for your patience...
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: frustrated with rebuild process... [Re: 84toyota] #696536 02/27/06 04:44 AM
missouriman Offline
do you have a factory service manual? if not get on ebay and find one.
or call engbuilder, he is a busy man but will take the time to help people out. who rebuilt your motor, you could go back to them.
those plugs have a place. sorry man.
Re: frustrated with rebuild process... [Re: 84toyota] #696537 02/27/06 06:08 AM
engnbldr Offline
>>>On the bottom of the engine, near the center, inside. Easy to spot there is only one. It just plugs off the oil galley. Most of them are square drive, we have seen a few that were Allen head plugs though.
If that is missing there will be no oil pressure, it just pumps into the pan....*EB
*Beats the he** outa me!....*LOL**...
Re: frustrated with rebuild process... [Re: engnbldr] #696538 02/27/06 06:33 AM
CJM Offline
you can kinda see it in this pic ... right up from the motor mount bolt holes
sorry its the best one I got .
83 Trekker SR5
NEW Trekker forum
Re: frustrated with rebuild process... [Re: CJM] #696539 02/27/06 05:21 PM
84toyota Offline OP
[email]SH@T![/email] I don't know if that one is in there or not... I guess I'll have to pull the pan to find out... I guess one of these days I'll learn... I even made it a point to check and double check everything as I went...
Ken
Re: frustrated with rebuild process... [Re: 84toyota] #696540 02/27/06 07:53 PM
Esquire812 Offline
Sorry for the low quality picture, red arrow is the galley plug being referred to.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: frustrated with rebuild process... [Re: engnbldr] #696541 03/01/06 05:34 PM
84toyota Offline OP
Well... I was in fact missing the oil galley plug down by the pan rail... I put one in there, and should know in a few days if that cures my problem! The oil galley plug in the back of the motor was there... It seems my oil pan was leaking back there (A lot! - Right at the corner). Now I just have to figure out how to keep that pan from leaking. I've tried the cork gasket, and I've tried just using FIPG... <img src="/forums/images/graemlins/frown.gif" alt="" /> Maybe the cork gasket, and a bunch of FIPG around the outside edge of the pan will fix the problem...?
Thanks to all for the help and great advice!
Ken
Re: frustrated with rebuild process... [Re: 84toyota] #696542 03/01/06 06:16 PM
Esquire812 Offline
If the pan is still off, try flattening out the mounting flange using a block and hammer. Over-torqueing distorts the rail, pan bolts need to be torqued in a criss-cross pattern to something like 9 or 14 ft lbs. Not much.
85' Sillyca 22R-Esq
Re: frustrated with rebuild process... [Re: Esquire812] #696543 03/01/06 07:17 PM
Myota Offline
9ft-lbs. I just put mine back on.
-Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: frustrated with rebuild process... [Re: 84toyota] #696544 03/01/06 10:51 PM
MrWiretender Offline
Ole' EB sure does know his stuff. The old sharpshooter got to heart of your problem with one shot. <img src="/forums/images/graemlins/patriot.gif" alt="" />
'87 22RE
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6392 MB (Peak: 0.7477 MB) Data Comp: Off Server Time: 2026-06-10 07:22:54 UTC
