Re: 10w30 for a 2.7L ? [Re: nuclear3579] #696754 02/15/06 02:28 PM
ACES_HI Offline
5W-30 is recommended and since its thinner than 10W-30 the engine will turn easier resulting in more power.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: 10w30 for a 2.7L ? [Re: foxtrapper] #696755 02/15/06 05:00 PM
hupptoy Offline
Mix oils to you hearts content. They are absolutely required to be compatable, and are.
Mixing an old SC oil with a newer SJ oil gives you the overall properties of the SD. Mixing a 10w-30 with a 20w-50 does indeed give you roughly a 15w-40. Mix synthetics with regular oils if you wish. Then you can brag about running a synthetic blend.
The only oil mix I wouldn't do is running a non-detergent oil. It does promote sludging and certainly isn't good in a modern engine. Modern being anything made after the early 60's in this case.
I compeletely agree with everything foxtrapper said. Anyone who says you can not mix brands or dino/syn is seriously misinformed. <img src="/forums/images/graemlins/confused.gif" alt="" />
B- Run a synthetic motor oil (not castrol it's fake synthetic).
Also, J94, what exactly is *fake synthetic*??? <img src="/forums/images/graemlins/confused.gif" alt="" />
And 5W30 is specified on newer engines because it provides more power and better mileage than thicker oils. That is also why some cars spec 0W20 nowadays.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: 10w30 for a 2.7L ? [Re: 4WD22R] #696756 02/15/06 06:40 PM
F
Flannelman Offline
I've always run FRAM filters, and like we've talked about before, as long as you check the anti-drainback valve then you're good to go. In the 3 cars I've owned, always changed the oil every 3K and the filter was always full of oil when I removed it. Seem to work for me....no oil-related engine problems yet......
I've also never had a problem with fram they seem to filter well and I've yet to have one that I pulled off that wasn't full of oil.
1997 T-100 100k and counting Green
5spd 4x4 Ext Cab isr mod Aisin Manual hubs
Re: 10w30 for a 2.7L ? [Re: hupptoy] #696757 02/16/06 02:14 PM
nuclear3579 Offline OP
Toyota Canada recommends 5w30 year round here in the Canadian Climate.
I think 10w30 is what I run in my 2.7;
when in doubt.. 10W-30. it's a one size fits all type oil.
i think the newer engines recommend 5w30 for all-around usage.
Just for kicks, I actually called two different Toyota Stealerships. And just as I suspected, one recommended only 10w30, the other only 5w30. Interesting. I'll probably change it out with the remaining 10w30 I have from the pickup. I have 5 quarts left, no need to waste it all. Thanks for all your input! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Too close for missiles, I'm switching to guns...
'97 4Runner...SR5, 4cyl (3RZ), 5spd, 4wd, no rust, excellent shape.
Re: 10w30 for a 2.7L ? [Re: nuclear3579] #696758 02/16/06 03:18 PM
1
1986xtracab Offline
synthetic oil and a good woven filter. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 10w30 for a 2.7L ? [Re: 1986xtracab] #696759 02/16/06 05:14 PM
87Toy4x4 Offline
why dont you just take a look at the manual?
Re: 10w30 for a 2.7L ? [Re: nuclear3579] #696760 02/16/06 05:26 PM
It never came with one when I bought it...bummer
Re: 10w30 for a 2.7L ? [Re: nuclear3579] #696761 02/16/06 06:45 PM
4WD22R Offline
why dont you just take a look at the HAYNES manual?
Changed it. No excuses now. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6290 MB (Peak: 0.7289 MB) Data Comp: Off Server Time: 2026-06-23 13:06:20 UTC
