Page 2 of 3 1 2 3
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Boertjie] #697652 02/20/06 04:08 PM
powerRam50 Offline
the ring gear sizes are right as far as i know it should be perfect.if somebody is reading this this and has a caps program can you take a look.
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Boertjie] #697653 02/20/06 05:03 PM
lordtrunks Offline
Well i can't tell what size they are but i can give you part numbers using caps which may inturn help you out.
MB185452 front
MB185461 rear
I pulled these numbers up using a 2.6 powered 4wd truck.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: powerRam50] #697654 02/20/06 06:35 PM
L
Lee N Offline
I'm suprised your diesel has the small front diff. The 5.29 gears Mr. Bishi first found for the Gen I were from a diesel and these were the larger 8" front ring gear. Have you looked at your front diff to verify the size? I'd search for some pictures to see what the differences are. I don't have a european CAPS program, so can't positively track it down.
Here's a pic of an 8" front diff -
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Lee N] #697655 02/20/06 07:35 PM
PHIL_ Offline
I was about to question the front diff as well, Lee. From my understanding, the genI had the 8" front diff, auto or standard: the genII auto went to the 7.5" for the front diff, and the standard cont'd to have the 8". But then he has rear leafs, so perhaps his truck was outfitted like the 2.6's? Hmmmm... the two 4d56 GenI diesels I've looked over in person have had coils and they were outfitted with diffs the exact same as my genI 3.0-V6.
PHIL
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: PHIL_] #697656 02/20/06 09:54 PM
DarthRaider Offline
"The Gen3 Di-D comes with 1:3.9 diffs, so I thought that would be about what I needed"
You are running a 31" tire is that what is stock on a Gen3 with 3.9 gears? What I am saying is I would hate to see you go to far and be meltin your clutch to get the thing goin. I am sure HP and torque are not an issue from your new swap but you still need to be able to apply the power. Are you doing this to gain MPG or just to go faster on the highway? <img src="/forums/images/graemlins/cheers.gif" alt="" />
87 Dodge Raider w/mits 2.3 Turbo Diesel 5 speed
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: powerRam50] #697657 02/21/06 01:46 PM
Boertjie Offline OP
Thanks guys for all your input so far. I really appreciate it.
PowerRam: Thanks for doing the research.
lordtrunks: Are those part nos for 8" diffs with 1:3.9 ratios?
Lee N: Thanks for the pics, I will crawl under the truck and take some photographs, which I will post tomorrow (22nd).
Does anyone have pics of 7.25" diffs, to confirm the difference?
PHIL: You said
exact same as my genI 3.0-V6..
What is the spec then for the 3.0V-6? 8" front and rear?
DarthRaider: The Gen3 Di-D has 1:3.9 on 16" tyres which are just about 31" dia. My Gen1 is obviously lighter than the Gen3, so the ratios will hopefully be OK.
My brother did the Di-D conversion into a Gen2 SWB. He swapped complete diffs from a Gen3 (1:3.9) into his Gen2 and the ratios are OK.
My main aim is better mpg and lower revs at cruising speeds (related aims I suppose).
Thanks again guys, or as we would say in Afrikaans:
"Baie dankie manne!"
1989 Exceed LWB
4m41 (3.2DiD TurboDiesel
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: Boertjie] #697658 02/21/06 06:26 PM
lordtrunks Offline
nope that would be the 8" rear and the 7.5" front
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: lordtrunks] #697659 02/22/06 06:08 AM
DarthRaider Offline
I not sure what you mean by "caps" but I have a Hollander crossover book (junkyard bible) at work and also a Chiltons labour and parts guide.(supplies me with OEM #s) They were both not completely clear as 83-86 pickup 4x4 used lordtrunks #s for the rear but not his # in the front for those years. His # was good for the front in 87 truck tho. <img src="/forums/images/graemlins/confused.gif" alt="" /> Is that because the 87 only used the 7.5 front diff? Like I told Phil in another post my donor pickup 84 Dodge D50 diesel has the 3.909 gears with 8" in the front and back. Maybe my donor truck is special (being a diesel)and should have 7.5 in the front? (the hollander book usually has separate listing if they are special) <img src="/forums/images/graemlins/cheers.gif" alt="" /> Don't think I am helping here sorry <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: DarthRaider] #697660 02/22/06 07:12 AM
lordtrunks Offline
caps is the mitsu dealer program it doesn't show the diesel pickups the diesels are in the fish books.
Re: Taller gears for my Gen1 Di-D. Help needed. [Re: DarthRaider] #697661 02/22/06 07:42 AM
Boertjie Offline OP
I found this site:
Rear diff:
http://www.forceauto.ru/_pages/chry...93Nj09M3x8cm93NT09MDAwMTEwMHx8aT09MTE%3D
Front diff:
http://www.forceauto.ru/_pages/chry...93Nj09Mnx8cm93NT09MDAwMTgwMHx8aT09MTg%3D
Are those the parts I'm looking for?
This site seems to be handy, start here:
http://www.forceauto.ru/catalogs/ch...mp;amp;group=2&sgrp=837020001200
Here are some pictures of my diffs:
Rear:
Front:
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 2.014s Queries: 15 (0.006s) Memory: 0.6454 MB (Peak: 0.7558 MB) Data Comp: Off Server Time: 2026-11-16 01:17:51 UTC
