Re: d60's #697749 03/09/06 05:19 AM
cuervo25 Offline
ford f250's have high pinion dana 60's in the front end :p
Sorry, but no. An F250 either has a Dana 44 or a Dana 50. Only the F350 had the HP Dana 60. Some F350s (80-84) only had the Dana 50.
So reign is right f250's had a hp d60, but to be exact here is how it goes.
67-79 f 250s had d44's in 74 and 75 they had a hp closed knuckle d 60 as an option on heavy duty and 76-77 they had a open knuckle hp d 60 on crew cabs and snow fighters.
As for the d 50's i dont know much about them but i belive they were pre 02 but how far back they went i dont know.Dodge w200,250,300,and 350 also had d44s and d60's on the front ends from 72-93.GM used d44's gm 10 bolt and d 60's73-76 d 44's77-87 they had all 3.
i am not sure on the years newer than i listed but the point is if you go to a bone yard one of the big 3 will have them.Dont limit yourself just to the 3/4 tons either look at one tons also to improve your chances
Re: d60's [Re: cuervo25] #697750 03/10/06 02:42 AM
I read reign's statement to apply to all F250s, which just isn't so. Yes the snowfighters and crew cabs had the D60 for two years. Now try to find one still in existence. Generally speaking nobody should expect to find a Dana 60 under an F250. Chances are better to get a winning lotto ticket.
The Dana 50 goes back to 1980 with the introduction of the Twin Traction Beam front suspension.
Re: d60's #697751 03/10/06 04:47 AM
cuervo25 Offline
that is why i also listed GM and DODGE as having d60's ,with dodge being a better chance in the location of a d60. I should know that,dad has several of them.I just dont know what it is about chryslers and danas but they worked together for many many years.
Re: d60's [Re: cuervo25] #697752 03/11/06 02:02 AM
So what did Dodge and Chevys having Dana 60s have to do with finding one under an F250???
I fail to see the relation, only a tangent. Dana 60's aren't hard to find from under Fords. That wasn't the point. The point was that finding one under an F250 specifically is like finding a needle in a haystack. The important qualified is D60 in F250, not Ford in general.
Re: d60's #697753 03/11/06 03:51 AM
cuervo25 Offline
well actually no it isnt look it up on ebay tons of them there (dang i sound like BJ LOL) in fact i looked last night.perhaps you you should do some more looking yourself
Re: d60's [Re: cuervo25] #697754 03/11/06 01:07 PM
superdawg Offline
Maybe SD can get us a picture of a 35 sitting next to a 60?
CSP, That would be nice, but all the 35s are in the scrapper (or should be).
Here is the real deal, unless you are a total throttle jockey and run 38"+ tall tires they are NOT needed.
A well built d44 with a somewhat sane driver and 38"max tires can work very well and NOT leave you having spent all your hard earned cash and no money to go wheeling with it.
SD
I build and ship axles anywhere in the US.
Re: d60's [Re: superdawg] #697755 03/11/06 06:48 PM
valleycat Offline
do you have or can you get 2.5 ton rockwells? i have a friend trying to find some right now. even if you don't deal with rockwells, do you have a rough guess of the shipping cost to phoenix from colorado?
Re: d60's [Re: valleycat] #697756 03/12/06 02:51 PM
superdawg Offline
Do you want both to be steering axles?
SD
Re: d60's [Re: superdawg] #697757 03/12/06 06:02 PM
valleycat Offline
no, 1 front, 1 rear.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6270 MB (Peak: 0.7422 MB) Data Comp: Off Server Time: 2026-10-23 02:16:43 UTC
