Re: 3.5L Crank Bolt Broke #698341 02/20/06 08:20 PM
LRJ4x4 Offline
I'm just throwing this out as a idea but if the timing belt has already been changed can you WELD the pully to the shaft?
Re: 3.5L Crank Bolt Broke #698342 02/20/06 09:22 PM
hotrod4x5 Offline
Sorry to hear of your trouble. The same exact thing happened to me. My crank bolt broke off and just as I got to the side of the road my crank pulley hit the pavement too.
I managed to get the broken half out with a right angle drill and bolt extractor, both from sears. I didn't use anything to center it, just eyeball, and in fact I didn't get it centered, but the extractor worked great.
If you can get $3,000 that is awesome, I think. I have been thinking about fixing mine as it sits in the driveway, but now I dislocated my elbow a month ago and am still in recovery.
We have decided to sell ours and actually I just came here and saw your post as I am looking for a place to list ours.
Good luck!
Rodney,95 SR 3.5 L, Rancho RS 9000's, 31x10.5-15 Bridgestone Dueler A/T's, OEM Rear locker My Monty in action!
Re: 3.5L Crank Bolt Broke [Re: LRJ4x4] #698343 02/22/06 12:11 AM
Thanks, your the second person to mention this (welding) but I miss understood the first and thought he was talking about the bolt, but welding the pulley makes sense. I can get that done at the auto-crafts shop pretty cheaply.
Thanks for your input.
Re: 3.5L Crank Bolt Broke [Re: LRJ4x4] #698344 02/22/06 01:38 AM
P
pcc Offline
I'm not sure welding would be an option. It is very difficult to weld high carbon steel(crank) to mild steel(pulley). I would consult a certified welder first before trying to get the shop guy to just mig weld it.
Re: 3.5L Crank Bolt Broke [Re: pcc] #698345 02/22/06 04:41 PM
W
Winston Offline
Plus the heat would damage the crank seal.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6133 MB (Peak: 0.6737 MB) Data Comp: Off Server Time: 2026-05-29 18:49:42 UTC
